The eurorace header just showed up, YES! |
purple |
Oct 3 2007, 10:12 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
Hey guys, this is something of a continuation thread of these last two threads.
http://www.914world.com/bbs2/index.php?showtopic=76498 http://www.914world.com/bbs2/index.php?showtopic=76175 The eurorace header showed up today! YES!!! Here is a pic of it sitting in the garage somewhat assembled. Now I have a couple questions: 1: Do I use only new copper gaskets? 2: Is there a specific procedure to preparing the gaskets prior to install? 3: Should I use those copper nuts or just double nut the stub pipes to the exhaust ports? 4: Should I do a little dance after putting it all on without any pulled studs? I'll post a pic of the dual motorcycle exhaust once I launch my other computer. If Jake signs in....how much will this help my engine over that dual motorcycle exhaust? Attached thumbnail(s) |
purple |
Jun 4 2008, 04:54 PM
works great! ended up running the clutch cable underneath the header, havent caught it on anything (yet)
the only issue i guess is to not let it idle too much in one spot, the heat from the pipe may start to warp the console cover on a sideshifter a bit. not much, but it did do it to me also, dont wrap the thing. it will destroy itself FAST if you do that. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:29 AM |
