Hey /6 guys 911 2.4 engine question(s), AKA I have oil issues :-( |
GaroldShaffer |
Jul 22 2008, 05:20 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
The short version:
I have a old 914 FP race car that is "this close" to having the /6 conversion completed. The engine is a 2.4 911 T with carbs. All new -12 areo quip lines, new oil tank, thermosta, and remote oil filter console. Car is at Brad Mayuers shop. Here is the issue with everything hooked up Oil will build up in the crank case to the point the oil tank starts to suck air and the over flow tank fills with oil. When drained, over 1 1/2 gallons of oil comes out of the crank case. Now with the remote oil filter, oil cooler and such bypassed and the line connected back to the oil tank the oil flow is better, not great, but better. When drained about 3 quarts of oil comes out of the crank case. Seems to Brad that I have a scavage pump problem, yes? Is there anything else that we should look for? If Brad is stumped, then I sure the hell have no clue. I will not take this engine apart. If it comes to that then my /6 project is done for a while until I build up enough funds to get another engine. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/headbang.gif) |
Justinp71 |
Jul 23 2008, 11:29 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Well in basic principal either what ever pushs the oil out of the motor (scavange pump) is not working or there is a blockage in the oil passage going to the oil tank.
Maybe drain the oil lines from the motor exit to the oil tank and see if you can push air thru them. Would it be possible to have a defective thermostat or something? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:23 AM |
