> What Welder to buy, I show my ignorance inside!
Hawktel
post Jan 13 2004, 06:35 PM
Okay I figure might as well take the plunge, and buy a welder.
I know nothing about welding. I've never welded anything. I think I understand the basic principle. But if you were to blow a couple hundred bucks, to have a portable weilder setup, just work on cars, what would you get?
I was considering this little unit off ebay.
Ebay Welder link
Specifically, I'd want to use it to replace the battrey shelf, some trunk rust repair, and replace some brackets for the floods and such.
If you wouldn't use the above, what would you use?
(IMG:style_emoticons/default/pray.gif)
Hawktel
post Jan 18 2004, 04:21 PM
I think that is what I'll get, the ones Rustywa listed. I'll just rent a bottle locally, and be good to go.
Hawktel   What Welder to buy   Jan 13 2004, 06:35 PM
TimT   Save your bucks and buy a Lincoln or a Miller, not...   Jan 13 2004, 07:01 PM
ppickerell   Buy a small Lincoln MIG. Much better suited for al...   Jan 13 2004, 07:02 PM
rick 918-S   Electric arc is much more suited to 1/8 steel than...   Jan 13 2004, 07:07 PM
URY914   You may also ask yourself if you want to spend +/-...   Jan 13 2004, 07:17 PM
Hawktel   Okay the Stick welder is for big Stuff? Whats a Mi...   Jan 13 2004, 07:37 PM
redshift   Rent, borrow, steal. M   Jan 13 2004, 07:46 PM
stock93   I made the mistake of buying an arc welder first w...   Jan 13 2004, 07:47 PM
seanery   MIG is easy to learn. I taught my buddy to do it i...   Jan 13 2004, 07:54 PM
redshift   Sean is right about the slag. :) M   Jan 13 2004, 07:57 PM
Hawktel   Okay. So Mig. Whats the difference between Wire Fe...   Jan 13 2004, 08:05 PM
Malmz   Keep an eye on Ebay, pawn shops, etc for a Mig. I...   Jan 13 2004, 08:21 PM
fraggle00   I'm the same boat as Hawktel. I figured ~...   Jan 13 2004, 08:23 PM
steve@ottosvenice.com   Use this welder with or without gas. Comes with we...   Jan 13 2004, 08:34 PM
Hawktel   To bad your up in Boise Fraggle. We could split th...   Jan 13 2004, 08:35 PM
Hawktel   Okay Steve. Thats the ticket I'll start lookin...   Jan 13 2004, 08:38 PM
trojanhorsepower   I took the plunge and got the Lincoln 135A mig. I...   Jan 13 2004, 08:52 PM
seanery   don't buy crap. Stick with a good company. M...   Jan 13 2004, 08:57 PM
TimT
  Jan 13 2004, 09:06 PM
L8Apex   I got a "cheap" Hobart 135 MIG welder. I think Ho...   Jan 13 2004, 09:26 PM
thomasotten   Ok, I have been doing just fine with a Campbell Ha...   Jan 13 2004, 09:38 PM
eldiosyeldiablo   WARNING: Extreme novice question.... my welding bo...   Jan 13 2004, 09:40 PM
Gint   I bought a Miller 175 so I wouldn't have to do...   Jan 13 2004, 11:03 PM
rick 918-S   Dont forget about Century. I have a 25 yr old Snap...   Jan 13 2004, 11:54 PM
Malmz   There are both 110 and 220 welders out there. The...   Jan 14 2004, 12:00 AM
L8Apex
  Jan 14 2004, 01:05 AM
Racer Chris   Lincoln SP125 is about the best 110V machine avail...   Jan 14 2004, 02:01 AM
redshift
  Jan 14 2004, 08:10 AM
redshift   ;) not being a complete smartass... but if you lo...   Jan 14 2004, 08:13 AM
Gint
  Jan 14 2004, 08:17 AM
fraggle00   I'm lucky... Previous owner of my house had a...   Jan 14 2004, 10:06 PM
ppickerell   Not an expert, but Harbor Freight not known for qu...   Jan 14 2004, 10:16 PM
cha914   :agree: If you can't afford a new one, try a...   Jan 15 2004, 01:20 PM
bongo monkey   I use my Miller 350LX TIG welder whenever possible...   Jan 15 2004, 04:08 PM
RustyWa   This looks like it could be a pretty good deal for...   Jan 18 2004, 04:11 PM
Hawktel   I think that is what I'll get, the ones Rustyw...   Jan 18 2004, 04:21 PM
seanery   As long as 85 amps is enough. What's the duty ...   Jan 18 2004, 04:28 PM
trojanhorsepower   Hawktel I would recommend that you buy your bottle...   Jan 18 2004, 04:32 PM
airsix   I'm with Gint. The Hobart "Handler 135" totall...   Jan 19 2004, 12:54 PM
Gint   LOL. I bought my Miller 175 (220V) so I wouldn...   Jan 19 2004, 01:46 PM
eldiosyeldiablo   How is the Lincoln Electric Well Pak 3200 HD. I fo...   Jan 21 2004, 09:28 PM
eldiosyeldiablo   bump? No reponses so I'll pass on it then.   Jan 22 2004, 03:28 PM
Jeff Bonanno   Lincoln Electric 3200 HD specs at least you would...   Jan 22 2004, 04:27 PM
BGman   my .02, I am not a great welder....but I work arou...   Jan 22 2004, 07:13 PM
Sammy   Uhhhhmmmm, A stick welder and a wire feed welder...   Jan 25 2004, 03:40 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:50 PM
