| Hawktel |
Jan 13 2004, 06:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 2-April 03 From: Ogden Utah Member No.: 506 |
Okay I figure might as well take the plunge, and buy a welder.
I know nothing about welding. I've never welded anything. I think I understand the basic principle. But if you were to blow a couple hundred bucks, to have a portable weilder setup, just work on cars, what would you get? I was considering this little unit off ebay. Ebay Welder link Specifically, I'd want to use it to replace the battrey shelf, some trunk rust repair, and replace some brackets for the floods and such. If you wouldn't use the above, what would you use? (IMG:style_emoticons/default/pray.gif) |
| airsix |
Jan 19 2004, 12:54 PM
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I'm with Gint. The Hobart "Handler 135" totally rocks for home use. I got this model because it was the highest rated 115v mig (25% duty cycle @ 135 amps). I wanted the 115v so I could use it anywhere. It is plenty powerful. Last night was welding 5/8" plate with it and had to turn down the heat because it was undercutting. It does just fine. When it comes to tools at my place it's "King of the garage". Another thing I like is that it came ready for gas. Just hook up the bottle and go. Nothing else to buy (except wire).
Call around to the local shops. I got mine in January two years ago - they were blowing them out as an after-Christmas sale. Got a great deal and it's paid for it's self dozens of times. -Ben ps - The famous bumblebee that Rusty and Pam resurected... they did all the sheetmetal work with a Hobart Handler 110v MIG. |
Hawktel What Welder to buy Jan 13 2004, 06:35 PM
TimT Save your bucks and buy a Lincoln or a Miller, not... Jan 13 2004, 07:01 PM
ppickerell Buy a small Lincoln MIG. Much better suited for al... Jan 13 2004, 07:02 PM
rick 918-S Electric arc is much more suited to 1/8 steel than... Jan 13 2004, 07:07 PM
URY914 You may also ask yourself if you want to spend +/-... Jan 13 2004, 07:17 PM
Hawktel Okay the Stick welder is for big Stuff? Whats a Mi... Jan 13 2004, 07:37 PM
redshift Rent, borrow, steal.
M Jan 13 2004, 07:46 PM
stock93 I made the mistake of buying an arc welder first w... Jan 13 2004, 07:47 PM
seanery MIG is easy to learn. I taught my buddy to do it i... Jan 13 2004, 07:54 PM
redshift Sean is right about the slag.
M Jan 13 2004, 07:57 PM
Hawktel Okay. So Mig. Whats the difference between Wire Fe... Jan 13 2004, 08:05 PM
Malmz Keep an eye on Ebay, pawn shops, etc for a Mig. I... Jan 13 2004, 08:21 PM
fraggle00 I'm the same boat as Hawktel. I figured ~... Jan 13 2004, 08:23 PM
steve@ottosvenice.com Use this welder with or without gas. Comes with we... Jan 13 2004, 08:34 PM
Hawktel To bad your up in Boise Fraggle. We could split th... Jan 13 2004, 08:35 PM
Hawktel Okay Steve. Thats the ticket I'll start lookin... Jan 13 2004, 08:38 PM
trojanhorsepower I took the plunge and got the Lincoln 135A mig. I... Jan 13 2004, 08:52 PM
seanery don't buy crap.
Stick with a good company.
M... Jan 13 2004, 08:57 PM
TimT
L8Apex I got a "cheap" Hobart 135 MIG welder. I think Ho... Jan 13 2004, 09:26 PM
thomasotten Ok, I have been doing just fine with a Campbell Ha... Jan 13 2004, 09:38 PM
eldiosyeldiablo WARNING: Extreme novice question.... my welding bo... Jan 13 2004, 09:40 PM
Gint I bought a Miller 175 so I wouldn't have to do... Jan 13 2004, 11:03 PM
rick 918-S Dont forget about Century. I have a 25 yr old Snap... Jan 13 2004, 11:54 PM
Malmz There are both 110 and 220 welders out there. The... Jan 14 2004, 12:00 AM
L8Apex
Racer Chris Lincoln SP125 is about the best 110V machine avail... Jan 14 2004, 02:01 AM
redshift
redshift ;)
not being a complete smartass... but if you lo... Jan 14 2004, 08:13 AM
Gint
fraggle00 I'm lucky...
Previous owner of my house had a... Jan 14 2004, 10:06 PM
ppickerell Not an expert, but Harbor Freight not known for qu... Jan 14 2004, 10:16 PM
cha914 :agree:
If you can't afford a new one, try a... Jan 15 2004, 01:20 PM
bongo monkey I use my Miller 350LX TIG welder whenever possible... Jan 15 2004, 04:08 PM
RustyWa This looks like it could be a pretty good deal for... Jan 18 2004, 04:11 PM
Hawktel I think that is what I'll get, the ones Rustyw... Jan 18 2004, 04:21 PM
seanery As long as 85 amps is enough. What's the duty ... Jan 18 2004, 04:28 PM
trojanhorsepower Hawktel
I would recommend that you buy your bottle... Jan 18 2004, 04:32 PM
Gint LOL. I bought my Miller 175 (220V) so I wouldn... Jan 19 2004, 01:46 PM
eldiosyeldiablo How is the Lincoln Electric Well Pak 3200 HD. I fo... Jan 21 2004, 09:28 PM
eldiosyeldiablo bump?
No reponses so I'll pass on it then. Jan 22 2004, 03:28 PM
Jeff Bonanno Lincoln Electric 3200 HD specs
at least you would... Jan 22 2004, 04:27 PM
BGman my .02,
I am not a great welder....but I work arou... Jan 22 2004, 07:13 PM
Sammy Uhhhhmmmm,
A stick welder and a wire feed welder... Jan 25 2004, 03:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:50 PM |
