Dizzy or no dizzy?, D.W.D. already...? |
jhadler |
Nov 30 2008, 03:26 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
So here I am with a fully disassembled motor, ready for a bottom end rebuild in the ensuing weeks.
I have, in my possession, a 4 coil electromotive ignition setup that was given to me. I have all the parts I need (including the timing wheel) save the mount itself for the pickup. Should I go ahead and install it? And leave the dizzy on the bench? It's a tough call, but I thought I'd get some opinions from y'all... What to do? -Josh2 |
LarryR |
Nov 30 2008, 03:56 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
I have been hoping someone would come out with a low cost distribuless ignition for the TIV. Very few cars have distributors any more ... I was figuring a system from another 4 cyl could be canabalized for cheap.
Just reread your initial post. If you already have the electromotive might as well put it to good use. |
ClayPerrine |
Dec 26 2008, 07:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have been hoping someone would come out with a low cost distribuless ignition for the TIV. Very few cars have distributors any more ... I was figuring a system from another 4 cyl could be canabalized for cheap. Just reread your initial post. If you already have the electromotive might as well put it to good use. Years ago I put a GM 4 cylinder waste spark setup on my 2.0L engine. I put the pickup in the hole for the torque converter, and used the flywheel with grooves cut int he back for the trigger. Without a computer the limp-home advance curve on it is almost identical to the advance curve on a Bosch 050 distributor. It worked fine until the starter hung and ate the ring gear. I replaced the flywheel, and put the distributor back in. I still have all the pieces in a box in the attic. It actually was part one of the GM Fuel injection setup I was adapting to the 914 engine. The bad starter and overall lack of money killed that project. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:32 PM |
