100mm output flange., Questions |
PeeGreen 914 |
Jan 14 2009, 04:23 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
So I need to get some 100mm output flanges to go with my 944 axles I want to use on my 914. I am thinking they come out of a 915. What do I really need to look for with my 901 box and is the 100mm measured from the bolt spacing or the distance across or?
I also was asked if I need coarse or fine spline. Ummmm.... 901 guys help me out here. Dr. Evil? Slits? anyone? |
SirAndy |
Jan 15 2009, 12:04 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I run a stock 901 behind my 3.6L /6 ...
So far, so good. I think they can hold up pretty well if you're older than 25 and got through your "must burn rubber on every light" phase with a different car. I don't use 1st gear anymore as i have been told it is the weakest spot in the 901. I got plenty of torque and taking off in 2nd is no problem at all ... As for the axles, i went with the modified 914 axles shaft and 100mm 944 CVs. No problems there either so far. HOW TO: Convert to real 5-lug in the rear using 944 CVs http://www.914world.com/bbs2/index.php?showtopic=80641 By using the modified 914 axles shaft, you eliminate any length problems and there's no need for spacers. The 915 coarse spline output flanges are the same "depth" as the 901 output flanges. (IMG:style_emoticons/default/bye1.gif) Andy |
Lo-Fi Version | Time is now: 16th June 2024 - 05:21 PM |
