Black/brown wire near fuel tank, Where does it terminate? |
jjbunn |
Aug 15 2009, 12:42 PM
Julian Group: Members Posts: 121 Joined: 20-May 09 From: Pasadena, CA Member No.: 10,383 Region Association: Southern California |
I'm trying to locate the black/brown wire marked "T1a" on the '74 wiring diagram, that is supposed be "near fuel tank", and which I think can be used to power an electric windscreen washer pump (it comes from the stalk switch on the steering column).
My problem is that I can't see where this wire is on my car. There is some overspray on the wire bundle that emerges into the front trunk from under the dash, which makes seeing what is there difficult. Any help/advice would be appreciated! |
SirAndy |
Aug 15 2009, 01:42 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm trying to locate the black/brown wire marked "T1a" on the '74 wiring diagram It's brown with a black stripe. Originates at your steering column and is in the main bundle going into the front trunk and terminates right around the drivers side fresh air divider box thing. It may be hidden inside the loom. It was on my car. http://www.914world.com/bbs2/index.php?showtopic=13261 (IMG:style_emoticons/default/popcorn[1].gif) Andy |
jjbunn |
Aug 15 2009, 03:53 PM
I'm trying to locate the black/brown wire marked "T1a" on the '74 wiring diagram It's brown with a black stripe. Originates at your steering column and is in the main bundle going into the front trunk and terminates right around the drivers side fresh air divider box thing. It may be hidden inside the loom. It was on my car. http://www.914world.com/bbs2/index.php?showtopic=13261 (IMG:style_emoticons/default/popcorn[1].gif) Andy OK I have found the wire: it emerged at the place you indicated, and was folded back and taped, hidden, to the wiring bundle. After extracting it, I checked for +12V when pulling the column stalk towards me: nothing. My car is a '74, but it doesn't have the intermittent wipe option - is that relevant? I'm a little confused now, as my owner's manual says that the windscreen washers are activated by pulling on this lever, as I am doing. Yet the system in the '74 used the spare tire pressure to eject the water, so how is the column stalk supposed to turn that on and off, and what has it got to do with the brown/black wire? Sorry, I'm new to 914 wiring (IMG:style_emoticons/default/blink.gif) |
SirAndy |
Aug 15 2009, 11:18 PM
After extracting it, I checked for +12V when pulling the column stalk towards me: nothing. My car is a '74, but it doesn't have the intermittent wipe option - is that relevant? I'm a little confused now, as my owner's manual says that the windscreen washers are activated by pulling on this lever, as I am doing. Yet the system in the '74 used the spare tire pressure to eject the water, so how is the column stalk supposed to turn that on and off, and what has it got to do with the brown/black wire? Sorry, I'm new to 914 wiring (IMG:style_emoticons/default/blink.gif) If i'm not mistaken, the stalk at the steering column grounds out the wire, not feed it with 12V ... It usually plugs into the intermittent relay harness, i'm guessing it get's voltage from there. In order to use it for the pump, use it as a ground for your pump or use it to ground out a relay that supplies 12V to your pump ... (IMG:style_emoticons/default/shades.gif) Andy |
jjbunn |
Aug 16 2009, 12:04 PM
After extracting it, I checked for +12V when pulling the column stalk towards me: nothing. My car is a '74, but it doesn't have the intermittent wipe option - is that relevant? I'm a little confused now, as my owner's manual says that the windscreen washers are activated by pulling on this lever, as I am doing. Yet the system in the '74 used the spare tire pressure to eject the water, so how is the column stalk supposed to turn that on and off, and what has it got to do with the brown/black wire? Sorry, I'm new to 914 wiring (IMG:style_emoticons/default/blink.gif) If i'm not mistaken, the stalk at the steering column grounds out the wire, not feed it with 12V ... It usually plugs into the intermittent relay harness, i'm guessing it get's voltage from there. In order to use it for the pump, use it as a ground for your pump or use it to ground out a relay that supplies 12V to your pump ... (IMG:style_emoticons/default/shades.gif) Andy I'm not getting any action on that wire at all. Measuring resistance to ground or to B+, it's infinite, whether the column switch is activated or not. I suspect it's not connected in the column, perhaps because I don't have the intermittent wipe option on my car (why would they cable the switch if the option wasn't selected?). So I will take a look at the wiring on the switch itself, which looks like it may be quite a game getting to (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 01:20 AM |
