Got a new toy. tool., JET Hobby Mill (914-8 and r/c wheels on my list!) |
RJMII |
Jan 20 2010, 09:29 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
For Christmas I scored a Jet Hobby Mill to go with all of my stepper motors and CAD-CAM software and 3-d scanner.
I still need to get the correct collet and end mills; but I'm quite excited to get started machining some parts. Does anyone have a 914 emblem I can borrow? Someone was wanting a 914-8 machined, and I need a 914 to scan and model to get to cutting out some aluminum parts. Also; does anyone have an R/C 914 setup? I'm planning on machining the Fuchs wheels out of aluminum and need someone to help me out with getting the offset and diameter just right. I'm also thinking of machining a 914-World emblem for the backs of our cars out of aluminum. If I do go for that, I'll snail one off to Eric first, get his opinion and stamp of approval. I've been studying online all of this stuff on CNC and machining and am quite excited to actually get going with some 'on hands' stuff! Any other suggestions, for things to carve out of some aluminum? Attached image(s) |
RJMII |
Jan 21 2010, 12:33 AM
ooh oooh... awesome; thank you for all of the help, guys!
Rick, same font as normal 914 emblems? And thanks for the wheel set loan! Are they a good offset? We'll have much closer than that by the time I get done playing. (IMG:style_emoticons/default/biggrin.gif) Mr. underthetire; This mill takes MT2 style stuff. It's definitely small! I'd like a few different shapes to get started with on the end mills. A ball headed one or two, a corner rounder or two, and then square nosed. I can adapt spindle speed to number of flutes and materials. I think I need hold down clamps as well. I haven't had a chance to check it all out yet. it showed up an hour before I went into surgery, and my dad unpacked it and set it up in his shop for me. He sent me that particular pic as well. I haven't even plugged it in yet. My excitement is growing. (IMG:style_emoticons/default/biggrin.gif) thanks again! |
underthetire |
Jan 21 2010, 11:31 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
ooh oooh... awesome; thank you for all of the help, guys! Rick, same font as normal 914 emblems? And thanks for the wheel set loan! Are they a good offset? We'll have much closer than that by the time I get done playing. (IMG:style_emoticons/default/biggrin.gif) Mr. underthetire; This mill takes MT2 style stuff. It's definitely small! I'd like a few different shapes to get started with on the end mills. A ball headed one or two, a corner rounder or two, and then square nosed. I can adapt spindle speed to number of flutes and materials. I think I need hold down clamps as well. I haven't had a chance to check it all out yet. it showed up an hour before I went into surgery, and my dad unpacked it and set it up in his shop for me. He sent me that particular pic as well. I haven't even plugged it in yet. My excitement is growing. (IMG:style_emoticons/default/biggrin.gif) thanks again! MT2 is not something I would have, my |
RJMII |
Jan 21 2010, 08:25 PM
MT2 is not something I would have, my Can you educatem me a little on the necessities of rigidity with the carbide bits? HSS vs carbide? Could I not still control spindle speed and plunge speed if the machine isn't stout enough to handle fast? hmm.. yes. ball mill, chamfer tool, and center cut. =o) I think using those terms I might be able to find more bits for purchase from vendors as well. Thank you again! |
underthetire |
Jan 22 2010, 12:29 PM
MT2 is not something I would have, my Can you educatem me a little on the necessities of rigidity with the carbide bits? HSS vs carbide? Could I not still control spindle speed and plunge speed if the machine isn't stout enough to handle fast? hmm.. yes. ball mill, chamfer tool, and center cut. =o) I think using those terms I might be able to find more bits for purchase from vendors as well. Thank you again! Carbide is the worst thing in the world if the machine is not rigid enough. They will chip and break where HSS is more flexible and won't. Speed does not matter so much, although carbide should be run much faster than HSS. It's all in the spindle and slide manufacturing. Any lateral movement will cause you nothing but headaches with carbide. We see this a lot even on the large CNC's, a cheap Hurco for example will not cut anywhere near like a Mori Seiki, and the tool life is double on a Mori. We are talking machines in the 75K to 250K range though. Not exactly garage stuff. Although I do know where a good used Mori is for 12K, I just don't have enough garage ! |
Lo-Fi Version | Time is now: 9th June 2024 - 07:17 PM |
