> Turbo Tie Rod Washers, Are they critical?
vesnyder
post Dec 22 2005, 05:04 PM
I just installed the turbo tie rods and did not install the washer that came with the kit that goes between the tie rod and the steering rack - are these needed?
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
That's what I was afraid of!! They were a bitch to tighten and they will be impossible when I install the washer.
craig downs
post Feb 2 2010, 12:56 AM
I was told that the spacers are for if your using the 914 struts and if you have 911 struts you don't need them. When I installed mine I used large washers instead of the spacers for the rack stoppers.
vesnyder   Turbo Tie Rod Washers   Dec 22 2005, 05:04 PM
bondo   Yes! They keep you fromn overextending (and de...   Dec 22 2005, 05:09 PM
TimT   You need the washers. Without then you will never ...   Dec 22 2005, 05:16 PM
porsche914blue   It seems some cars need them and others don't....   Dec 22 2005, 07:05 PM
FourBlades   Maybe someone knows the answer to this, or has the...   Feb 1 2010, 03:13 PM
type47   I thought the washers had something to do with ...   Feb 1 2010, 03:42 PM
McMark   The washers aren't for bump steer. You need t...   Feb 1 2010, 03:49 PM
Eric_Shea   I believe all spindle arms are not created equal. ...   Feb 1 2010, 04:05 PM
McMark   Part #4 is on the stock steering rack and serves t...   Feb 1 2010, 04:19 PM
McMark   Yup, the steering rack is a bar with teeth machine...   Feb 1 2010, 04:23 PM
SirAndy   Yup, the steering rack is a bar with teeth machin...   Feb 1 2010, 04:33 PM
Eric_Shea   This is where I'm a tad confused. With a TT...   Feb 1 2010, 06:02 PM
McMark   Nope, the TTR comes with a rubber block on the rod...   Feb 1 2010, 06:15 PM
Eric_Shea   Ahhhh... that's the part I forgot.   Feb 1 2010, 06:56 PM
jaxdream   I installed a set of the Lenforders ( spelling ) a...   Feb 1 2010, 11:36 PM
craig downs   I was told that the spacers are for if your using ...   Feb 2 2010, 12:56 AM
kconway   I was told that the spacers are for if your using...   Feb 2 2010, 09:33 AM
PRS914-6   I used 911 struts AND steering rack. The washers ...   Feb 2 2010, 10:26 AM
Eric_Shea   At this point it would be nice to do a strut compa...   Feb 2 2010, 10:36 AM
PRS914-6   I'm using the Koni's as well......no issue...   Feb 2 2010, 11:04 AM
FourBlades   :popcorn: :popcorn: :popcorn:   Feb 2 2010, 12:17 PM
McMark   A thin washer will work just fine. Also note that...   Feb 2 2010, 02:00 PM
FourBlades   Mark, Thanks for all your insights on this! ...   Feb 2 2010, 09:38 PM
McMark   The thin washers pictured above have the same OD a...   Feb 2 2010, 10:48 PM
914Sixer   I will try and get a picture later today. The sto...   Feb 3 2010, 11:40 AM
Eric_Shea   That's one of the obvious visual differences...   Feb 3 2010, 03:56 PM
McMark   '69 T Struts.   Feb 3 2010, 04:13 PM
kconway   I believe this to be a 911T strut I'm putting ...   Feb 4 2010, 12:20 AM
Gint   BTW, is there a special type of grease to use on t...   Feb 4 2010, 09:20 AM
Eric_Shea   It would be nice to lay them on their backs, each ...   Feb 4 2010, 08:35 AM
Eric_Shea   I don't really think it matters. The factor...   Feb 4 2010, 11:39 AM
914Sixer   Here is a picture of a 75 911 Boge and 73 914 Bils...   Feb 4 2010, 01:18 PM
FourBlades   Well maybe it is only the early 911 struts that ar...   Mar 20 2010, 08:23 PM
- Lo-Fi Version Time is now: 9th October 2026 - 06:20 PM
