| GreatPumpkin |
Mar 27 2010, 08:53 AM
Member ![]() ![]() Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
where should you put subs in the 914 i was thinking a small one on the passenger floor? what do you think? i dont have a center console.
| Mike Bellis |
Mar 27 2010, 09:37 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I used to build a lot of custom fiberglass boxes. It would be easy to fit a 10 inch woofer box in place of the passenger toe board.
Make a card board template of the box. You can also cover the factory toe board in plastic wrap and use it for the bottom template. once the glass dries, pull it off the foam toe board form. Then reinforce the inside of your form before building the top. Glass is messy but very easy! A modern 10 inch only needs about 1 cubic foot of air to sound good. My wife is 5"-2", her feeet don't even touch the toe board. I can build mine much deeper if needed. Too many other projects right now to get started... |
GreatPumpkin subwoofers Mar 27 2010, 08:53 AM
MikeSpraggi I voted 'other' as in no where. I like th... Mar 27 2010, 08:59 AM
ellisor3 This is the option I will use when I get there, yo... Mar 27 2010, 09:06 AM
Root_Werks
This is the option I will use when I get there, y... Mar 29 2010, 12:51 PM
Ian Stott I'm modifying my center console slightly to ac... Mar 27 2010, 09:06 AM
iamchappy Flame me, but i put two 8"subs in behind the ... Mar 27 2010, 09:10 AM
montoya 73 2.0
Flame me, but i put two 8"subs in behind the... Mar 28 2010, 05:57 PM
iamchappy
Flame me, but i put two 8"subs in behind th... Mar 28 2010, 07:29 PM
montoya 73 2.0 Stainless mixing bowls!!! That is cool... Mar 29 2010, 01:44 PM
sawtooth
[quote name='montoya 73 2.0' post='1293539' date=... Nov 12 2010, 10:35 AM
westtexass2k
[quote name='montoya 73 2.0' post='1293539' date=... Apr 4 2012, 08:47 PM
recko911
Flame me, but i put two 8"subs in behind the... May 3 2010, 10:38 PM
Ian Stott I bet that sounds great and doesn't look bad i... Mar 27 2010, 09:21 AM
tat2dphreak I plan to build a hidden "deck" under th... Mar 27 2010, 09:36 AM
Cevan Don't the console-mounted subs rattle the hell... Mar 27 2010, 09:43 AM
McMark I had this one built for me, but it needs some twe... Mar 27 2010, 09:48 AM
dr914@autoatlanta.com The stealth sub when hidden under the front passen... Mar 27 2010, 10:20 AM
johannes
The stealth sub when hidden under the front passe... Mar 27 2010, 11:34 AM
underthetire center console Mar 27 2010, 10:38 AM
ghuff The headrests.
I saw a pontiac grand am, all homi... Mar 27 2010, 11:25 AM
Jeffs9146 Here is where I put mine! Mar 27 2010, 11:27 AM
JRust I have a 10" sub in a fiberglass made to repl... Mar 27 2010, 11:29 AM
messix looky here http://www.914world.com/bbs2/index.php?... Mar 27 2010, 12:36 PM
messix here is moph's vendor thread. he has very good... Mar 27 2010, 12:49 PM
914coop I love what Chappy did, Seen it and heard it in pe... Mar 27 2010, 07:28 PM
Elliot Cannon Subwoofers should be put in your house. :lol4: Mar 27 2010, 07:31 PM
orange914 these where just set in and never hooked up, but t... Mar 27 2010, 08:53 PM
RJMII subs go behind the back seat. =o) Mar 27 2010, 09:03 PM
MoveQik
Truth be told.... Apr 4 2012, 10:31 PM
kfish914 Not sure where i originally found these pictures b... Mar 29 2010, 04:35 PM
Sleepin Shoot a PM to Rod (at least I think it is Rod...in... Mar 29 2010, 04:41 PM
Sleepin http://www.914world.com/bbs2/uploads_offsite/i62.p... Mar 29 2010, 04:56 PM
Millerwelds Front trunk:
With the custom cover I can put g... Mar 29 2010, 05:39 PM
oz371
http://www.914world.com/bbs2/uploads_offsite/i62.... May 4 2010, 01:13 AM
pillay2k Re: Rod's car
Have a look at the amp install i... May 4 2010, 03:35 AM
zymurgist I voted "other" as in, in a Honda. ;) May 4 2010, 05:27 AM
scotty b Other...as in tow vehicle or garage. Thats where w... Nov 10 2010, 06:45 AM
RJMII this one can double as a jackstand...
http://www.... Nov 10 2010, 08:38 AM
dflesburg GreatPumpkin needs to post a pic of what he create... Nov 10 2010, 08:50 AM
windforfun As far away from your kidneys as possible. Nov 10 2010, 03:49 PM
bigkensteele I think it depends on whether you want a nice soun... Nov 10 2010, 09:03 PM
abayer1969
I think it depends on whether you want a nice sou... Nov 11 2010, 04:54 AM
hot_shoe914 I voted other, as in a gay assed Miata! Nov 10 2010, 09:14 PM
windforfun
:l... Nov 11 2010, 12:11 PM
RickS Or the el cheapo way... may look bad but sounds g... Nov 12 2010, 01:05 AM
bandi Used to have a customer with a small (but decent q... Apr 4 2012, 08:34 PM
SchwarzHorse Thru-bolt 'em to the roof and play em for the ... Apr 4 2012, 08:39 PM
PancakePorsche I put a small powered sub made by Retrosound on th... Apr 5 2012, 12:31 AM
Mikey914 I have the black and charcoal both in stock, I wil... Apr 5 2012, 12:39 AM
effutuo101
here is moph's vendor thread. he has very goo... Apr 5 2012, 03:13 PM
effutuo101 ah, found the new web site. Apr 5 2012, 03:18 PM
Mikey914
We now have it set u... Apr 5 2012, 08:35 PM
jsayre914 Front Trunk FO SHO !!
:elvira: Apr 5 2012, 03:44 PM
computers4kids Floor works great!
http://www.914world.com/bbs... Apr 5 2012, 11:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:59 AM |
