Subaru 6 Cylinder EZ30R Conversion PROGRESS, VIDEOS Cruising, Videos WOT!!!! |
budman5201 |
Apr 1 2010, 09:49 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
First pics of my EZ30R engine with 1000 miles total!
Now to take out the Ej20 turbo this weekend and see if the new engine can fit on the renegade engine cradle! Attached image(s) |
charliew |
Apr 8 2010, 01:12 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
If I remember right the 3.3 uses 2.2 stuff and the 30r has offset rods which means no aftermarket rods for boosting.
You can ceramic coat the tubes you've already started with. The LT1 motor mount uses a heat shield that looks like a turbo blanket. You might want to put one on your motor mounts if they are going to be that close to the headers. |
TwinTurbo914 |
Apr 8 2010, 01:27 PM
Member Group: Members Posts: 73 Joined: 29-May 03 From: NorCal Member No.: 752 Region Association: Northern California |
If I remember right the 3.3 uses 2.2 stuff and the 30r has offset rods which means no aftermarket rods for boosting. You can ceramic coat the tubes you've already started with. The LT1 motor mount uses a heat shield that looks like a turbo blanket. You might want to put one on your motor mounts if they are going to be that close to the headers. The 3.3 did use the 2.2 stuff, but the 3.0r does not have the offset rods, the 3.6r has them, the 3.0r is one the one you want to make big power as there is aftermarket pistons, sleeves, and rods unlike the 3.6r. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:38 PM |
