realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
looking for a good sandwhich adaptor to add an oil cooler. want one with a thermostat built in, I see several brands for sale, there are some big price differances too.
at any rate there are some ones that have 3/8 inch NPT inlet/outlet threads, and others that have 1/2 inch NPT threads inlet and outlet. the price differenace is considerable (nearly 3X) seeing as the oil passages upto the filter are not all that fat anyway I figure, how much benifit would one get out of a 3/8 NPT fitting verses the 1/2 NPT? I still plan to use AN10 hose and fittings and have 1/2 inch NPT on the oil cooler itself, so the biggest restriction in the new system would be the 3/8 NPT fittings on the sandwhich adaptor. will this be a significant flow restriction or not verses the larger adaptor? the engine will be a daily driver motor, not a high rpm race motor. |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
realred, don't foget this thread: http://www.914world.com/bbs2/index.php?showtopic=108328 . I am sure you will be fine with the 3/8 adapter. It will be winter before you get it ready to install if you keep lagging on getting your parts!
Lo-Fi Version | Time is now: 22nd August 2025 - 05:33 AM |
