> Electronic Ignition, WHAT TO USE
BarberDave
post Dec 3 2003, 05:58 PM
Barberdave
o.k., I have a newly rebuilt dizzy for my F,I, conversion. the only trouble is it still has points. I have Petroix (sp) in the one i have on my 914 with a carb now. QUES. is which electronic ignition to buy ?What is your experience?
Dave (IMG:style_emoticons/default/smilie_flagge6.gif)
mightyohm
post Mar 18 2004, 11:42 PM
For the tach signals, can't you just connect the tach to the points wire where it goes into the CDI box, instead of using the tach output?
I did that on my 72 911 with an MSD-6A and it worked great. No tach adapter needed.
BarberDave   Electronic Ignition   Dec 3 2003, 05:58 PM
!   Give the Petronix the float test...... I always u...   Dec 3 2003, 06:33 PM
Brad Roberts   All my Pertronix cars run just fine. The Allison/C...   Dec 3 2003, 06:37 PM
ChrisReale   My pertronix has worked great also...   Dec 3 2003, 06:38 PM
Brad Roberts   It works EVERY day in my wifes car (watch it will ...   Dec 3 2003, 06:43 PM
ChrisReale   Brad, when you move my car around, does it sould l...   Dec 3 2003, 06:49 PM
Kerrys914   Pertronix in my car and so far so good :) I do hav...   Dec 3 2003, 06:55 PM
robby750   I have run the Pertronix for almost 4 years withou...   Dec 3 2003, 06:58 PM
Brad Roberts   Mike hasnt owned a 4cyl 914 (that he drove on a re...   Dec 3 2003, 07:00 PM
philinjax   Jacobs Electronic Ignition or better yet, their ot...   Dec 3 2003, 07:01 PM
Brad Roberts   Hey Phil, Do they have a points replacement or is...   Dec 3 2003, 07:03 PM
TimT   I had the allison on a 911 I owned for about 10 yr...   Dec 3 2003, 07:10 PM
Aaron Cox   year and a half on my pertronix and counting.........   Dec 3 2003, 07:10 PM
serge914   I have a Mallory Unilite distributor and CDI with ...   Dec 3 2003, 07:29 PM
URY914   I'm running the Crane opitcal points, CD and c...   Dec 3 2003, 07:44 PM
Air_Cooled_Nut   Had Compufire electronic points in one car, Pertro...   Dec 3 2003, 08:37 PM
Doug Leggins   The pertronix is the best 60 bucks that I have spe...   Dec 3 2003, 08:44 PM
Aaron Cox   what does the msd 6al do?   Dec 3 2003, 08:54 PM
Brad Roberts   The MSD6al gives you soft touch rev control and gi...   Dec 4 2003, 02:11 AM
ArtechnikA   Crane HI-6 and optical points replacement all the ...   Dec 4 2003, 07:25 AM
KenH   Will the TACH work with the CRANE or do you need s...   Dec 4 2003, 11:30 AM
ArtechnikA
  Dec 4 2003, 11:46 AM
philinjax   Brad, Jacobs do not supply electronic points, ju...   Dec 4 2003, 12:10 PM
Brad Roberts   I have used the Crane pieces with success also. My...   Dec 4 2003, 01:56 PM
ArtechnikA   ...   Dec 5 2003, 06:45 PM
Rouser   Pertronix Ignitor, with Flame-Thrower coil and [ur...   Dec 5 2003, 09:48 PM
Jake Raby   Mallory........ Its adjustable and the best on the...   Dec 5 2003, 09:50 PM
Brad Roberts   Have you figured out a way to put the trigger poin...   Dec 5 2003, 11:45 PM
thesey914
  Dec 6 2003, 03:11 AM
ArtechnikA   ...   Dec 6 2003, 06:47 AM
Mark Henry   Has anyone tried the Gene Berg igniter on a type 4...   Dec 6 2003, 07:14 AM
Gint
  Dec 6 2003, 11:36 AM
Kargeek   I'm running an old school Permatune CD- I know...   Mar 19 2004, 12:53 AM
- Lo-Fi Version Time is now: 1st July 2025 - 08:08 AM
