> help with 3.2l conversion wiring, have a PMS 3.2l to 914-4 conversion cable but...
jim912928
post Dec 4 2010, 12:31 AM
Well, I have all of the mechanical work done for my 3.2l motronic conversion. Now I'm trying to figure out the wiring. I purchased the Patrick MotorSports conversion harness a few years back. It allows me to eliminate the relay board. However, electrical is not my forte...so I have some real questions on the "trunk" wires from the 3.2l harness and what to do with them. The engine, dme and wiring harness are all from the same car. So, here are my questions and you can relate them to the pictures as shown:
1. picture named "DME help" circle #1: by the dme connector...there are two little stub connections that seem to come out of the DME connector and both wires are brown....do these need to go to anything?
2. picture named "Trunk help" circle #2: I marked these fuel pump...do I cap these because I'm using the 914 wiring or do I need to connect them somewhere?
3. picture named "Trunk help" circle #3: I marked this positive battery...does the 914 harness cover this or do I need to connect it to the battery also?
3. picture named "Trunk help" circle #4: green and green/yellow wire...have no clue what this is?
4. picture named "Trunk help" circle #5: black wire by the wires I labeled "fuel pump"...have no clue what this is?
5. picture named "Trunk help" circle #6: white connector with a black, black/purple and yellow wire...have no clue what this is?
I also would like to know where you usually mount the DME and where do you pass it through from the passenger compartment into the engine compartment..and once on the engine compartment side...where do you route it up to the engine? Have pics from those angles?
Thanks all in advance!
Jim
DME help:
Trunk help:
shoguneagle
post Dec 5 2010, 09:57 PM
shoguneagle
echocanyons,
Sent an e-mail to you.
Steve Hurt
jim912928   help with 3.2l conversion wiring   Dec 4 2010, 12:31 AM
John   You are going to need a schematic and follow the w...   Dec 4 2010, 12:41 AM
shoguneagle   Whoa!!! Let us stop before going any ...   Dec 4 2010, 04:59 AM
jim912928   Thanks for the input so far. Here is additional i...   Dec 4 2010, 09:11 AM
shoguneagle   Hi Jim, The info I have given you thus far is not...   Dec 4 2010, 01:37 PM
mepstein   This is valuable information for all of us doing t...   Dec 4 2010, 02:10 PM
shoguneagle   Pictures: DME help: two brown wires which shoul...   Dec 4 2010, 02:49 PM
shoguneagle   Now to give some more back ground from the schemat...   Dec 4 2010, 03:19 PM
jim912928   Steve...sent you a pm with my email. It ha been 5...   Dec 4 2010, 03:54 PM
shoguneagle   Jim, There is an Tach up shift setup but I did no...   Dec 5 2010, 12:12 AM
jim912928   Thanks Steve!   Dec 5 2010, 09:36 AM
mepstein   Thanks Steve! :agree:   Dec 5 2010, 09:37 AM
echocanyons   Great thread. I am currently doing the same swap,...   Dec 5 2010, 12:07 PM
shoguneagle   The Patrick Jumper just takes care of the 14 pin c...   Dec 5 2010, 09:40 PM
shoguneagle   echocanyons, Sent an e-mail to you. Steve Hurt   Dec 5 2010, 09:57 PM
mepstein   Don't wait for me. I'm still buying parts ...   Dec 5 2010, 10:12 PM
jim912928   I was poking around the pelican site in the 911 fo...   Dec 5 2010, 10:50 PM
echocanyons   Thanks Steve. I plan to have the engine installed...   Dec 6 2010, 12:01 AM
Steve   Great info. The wiring is simple. All I did was ...   Dec 6 2010, 12:33 AM
jim912928   Steve from Laguna...since yours is running...could...   Dec 6 2010, 01:09 AM
mepstein   Steve & Jim - Do you have any other details of...   Dec 6 2010, 07:07 AM
MoveQik   Steve & Jim - Do you have any other details o...   Dec 6 2010, 10:07 AM
mepstein   Steve & Jim - Do you have any other details ...   Dec 6 2010, 12:42 PM
John   Steve & Jim - Do you have any other details o...   Dec 7 2010, 08:29 PM
Steve   I installed it 8 years ago. The motor came out of...   Dec 6 2010, 08:23 AM
jim912928   I found this diagram last night in the owners manu...   Dec 7 2010, 02:46 PM
mepstein   Will an optima battery fit in the normal location ...   Dec 7 2010, 08:37 PM
jim912928   ok...I think I have the mystery solved...I'll ...   Dec 7 2010, 08:42 PM
jim912928   A thought based on the info I outlined above. I h...   Dec 8 2010, 05:20 PM
shoguneagle   Now you are tracking on the right path. You migh...   Dec 9 2010, 03:26 PM
shoguneagle   Joe Sharpe did a great job on MoveQik's Sixer...   Dec 9 2010, 03:50 PM
mepstein   Joe Sharpe did a great job on MoveQik's Sixer...   Dec 9 2010, 04:18 PM
shoguneagle   Has everyone got a basic understanding of what is ...   Dec 9 2010, 06:15 PM
shoguneagle   What have I done to my car?? First one has to und...   Dec 9 2010, 07:19 PM
jim912928   I bought and learned how to use a multimeter! ...   Dec 10 2010, 11:33 PM
- Lo-Fi Version Time is now: 19th November 2026 - 11:05 PM
