Help for tubing fabricators - custom notching templates, Tube Coping Calculator |
aircooledtechguy |
Dec 31 2010, 11:09 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I ran across this nifty tube coping calculator on another board and had to share it here. Basically after you enter the specifics on the tube you are working with and the angle of intersection you want, it prints out a flat template that you can cut and wrap the tube with that shows the exact place to cut without the aid of an expensive tube notcher. Perfect for roll bars and cages. Hope this helps someone. . .
Tube Coping Calc. |
J P Stein |
Dec 31 2010, 06:24 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
A hole saw of the same diameter of the tube, a drill press, and a good drill vise do the trick.....a good eye for angles & a protractor help.
OR a $4-500 machine to do it. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:36 PM |
