> Anyone know the generic part # for rear wheel bearings?, And what shall I do while the arms are off?
stugray
post Jan 10 2011, 06:52 AM
Years ago, I needed to replace the bearings on either my Ghia or 914, and the VW dealer wanted an arm & leg for OEM.
I took the part number from the bearing and called a local bearing specialty house in Denver, and they had the exact same part for less than 1/4 of what the dealer wanted.
Anyone know a cross ref. part number for rear wheel bearings?
How about the dozens of bearings on ebay? Any good?
Any ideas for the best deal?
Oh, and what is the deal with the rear bearing seals?
The manual states that if these are damaged, the entire trailing arm needs to be replaced...
While I'm at it. Both arms are off and I am cleaning them up.
What does everyone suggest I do while I have them off?
I plan on painting them, but what else should I do while I'm at it?
I have the welder at the ready, so I could do some reinforcing too.
Stu
stugray
post Jan 12 2011, 06:31 AM
Funny,
Now that the part number above (545495AD) appears, I see that this topic has been discussed before:
http://www.914world.com/bbs2/lofiversion/i...php?t94702.html
Thanks for all the help.
Any opinions on what I should do to the arms while they are off?
I will reinforce them like the AA trailing arm plates before I paint them.
Has anyone ever considered having these parts plated for corrosion resistance during a refurb?
That would get the insides as well as the outsides....
Stu
rohar
post Jan 12 2011, 10:03 AM
QUOTE(stugray @ Jan 12 2011, 04:31 AM) *
Stu
I'm not sure about plating, never gone through the process. Keeping the bearing races clean might be an issue.
I taped over the bearing races with gorilla tape and tossed them in a poly cement mixer with a bunch of sand for a couple of hours. Clean as a whistle. Then added reinforcement, tumbled them shortly again and had them powder coated. Since I was there, did new bushings too.
stugray   Anyone know the generic part # for rear wheel bearings?   Jan 10 2011, 06:52 AM
type47   don't know cross reference but PET shows 999.0...   Jan 10 2011, 07:06 AM
914Sixer   There are no rear bearing seals. You may be confu...   Jan 10 2011, 07:11 AM
mepstein   Eric Shea- www.PMBPerformance.com   Jan 10 2011, 07:29 AM
dr914@autoatlanta.com   443 407 625 is another number. We have several di...   Jan 10 2011, 10:08 AM
andys   513106 is the generic number for the 914 rear whee...   Jan 10 2011, 11:07 AM
stugray   "513106" Now that's what I'm ta...   Jan 10 2011, 12:20 PM
Cap'n Krusty   It destroys the bearings. No way would I install ...   Jan 10 2011, 12:58 PM
andys   It destroys the bearings. No way would I install...   Jan 10 2011, 05:03 PM
rohar   I'm with the Cap'n. Of all the maintainan...   Jan 10 2011, 01:21 PM
stugray   Cap'n, Could you explain the "chill and ...   Jan 10 2011, 01:54 PM
mepstein   Cap'n, Could you explain the "chill and...   Jan 10 2011, 02:02 PM
draganc   Cap'n, Could you explain the "chill an...   Jan 10 2011, 08:09 PM
Mark Henry   I don't know how accurate this list is, but he...   Jan 10 2011, 02:59 PM
SLITS   I don't know how accurate this list is, but h...   Jan 10 2011, 06:37 PM
sww914   I have a pair of SKF in boxes on my desk. The 999 ...   Jan 10 2011, 10:30 PM
Eric_Shea   545495AD The 999 numbers are insaine. That's...   Jan 11 2011, 10:09 AM
Hans Zupp   545495AD The 999 numbers are insaine. That's...   Jan 11 2011, 05:28 PM
stugray   Funny, Now that the part number above (545495AD) ...   Jan 12 2011, 06:31 AM
rohar   Any opinions on what I should do to the arms whi...   Jan 12 2011, 10:03 AM
tradisrad   It's a good time to replace the bushings. How ...   Jan 12 2011, 09:03 AM
- Lo-Fi Version Time is now: 4th March 2026 - 06:53 AM
