> Corvair engine swap, Tell me why this isn't popular
914rat
post Feb 17 2011, 11:13 AM
I saw a car in the classifieds that has a Corvair 6 engine swap with the engine set up to run in the correct dirrection.I was wondering why we don't see this conversion very often.Seems like a pretty straight forward conversion.
http://www.914world.com/bbs2/index.php?showtopic=114974
RJMII
post Feb 19 2011, 09:30 AM
Jim McIntosh
What about flipping the R/P in the transmission instead of reversing the engine rotation ?? I know VW guys had been doing that for years. ???? just asking ??
the helical cut of the gears is going the wrong direction and it wouldn't be able to handle as much power.
JFJ914
post Feb 19 2011, 09:47 AM
QUOTE(RJMII @ Feb 19 2011, 10:30 AM) *
What????? The 901 was designed for the R/P to run in that direction (911). It's the 914 that runs it backwards!
RJMII
post Feb 19 2011, 10:35 AM
Jim McIntosh
QUOTE(John Jentz @ Feb 19 2011, 08:47 AM) *
You're not following the line of power quite right. The R&P is flipped AFTER the gear stack. The gear stack still rotates the same direction with the 911. With the Corvair engine the gear stack would be rotating the other direction. It's the helical cut of the gear stack that I was referring to, not the helical cut of the R&P.
914rat   Corvair engine swap   Feb 17 2011, 11:13 AM
pt_700   i suspect it's because there's not a lot o...   Feb 17 2011, 11:19 AM
9146986   The Porsche flat 6 (depending on the engine) can b...   Feb 17 2011, 11:27 AM
SirAndy   The Corvair engine is probably too rare to be popu...   Feb 17 2011, 02:58 PM
SirAndy   The Corvair engine is probably too rare to be popu...   Feb 17 2011, 07:22 PM
914rat   [quote name='SirAndy' post='1432761' date='Feb 17...   Feb 17 2011, 09:49 PM
914rat   The Corvair is much less expensive to purchase tha...   Feb 17 2011, 02:11 PM
zymurgist   Perhaps Dr Evil will chime in. He has a Corvair en...   Feb 17 2011, 02:22 PM
carr914   Your values on Porsche 911 Cores are way off. Plus...   Feb 17 2011, 02:23 PM
914rat   Your values on Porsche 911 Cores are way off. Plu...   Feb 17 2011, 02:50 PM
toon1   The Corvair is much less expensive to purchase th...   Feb 17 2011, 03:08 PM
914rat   The Corvair is much less expensive to purchase t...   Feb 17 2011, 03:40 PM
mepstein   I wanted a Porsche engine in my Porsche 914.   Feb 17 2011, 03:31 PM
zymurgist   I thought it was a good question. Not everybody re...   Feb 17 2011, 03:46 PM
r_towle   to rare IMHO equals a small market for parts, litt...   Feb 17 2011, 04:00 PM
Dr Evil   I am too busy to read the negative comments that t...   Feb 17 2011, 04:10 PM
bandjoey   I always thought it was poo pooed because it was a...   Feb 17 2011, 04:31 PM
tornik550   This stuff happens too often here- somebody asks a...   Feb 17 2011, 04:51 PM
RJMII   my answer: Ralph Nader. Personally if I were goi...   Feb 17 2011, 04:54 PM
toon1   [quote name='toon1' post='1432766' date='Feb 17 2...   Feb 17 2011, 06:48 PM
Dr Evil   I was doing a conversion on my 914 until a 2.7 dro...   Feb 17 2011, 06:51 PM
rick 918-S   I was doing a conversion on my 914 until a 2.7 dr...   Feb 17 2011, 07:04 PM
carr914   Your values on Porsche 911 Cores are way off. Pl...   Feb 17 2011, 06:57 PM
Lennies914   I built a corvair 7 years ago. It can get expensiv...   Feb 17 2011, 07:03 PM
GS Guy   I'm sure you'd get some serious double-tak...   Feb 17 2011, 07:24 PM
scotty b   I'm sure you'd get some serious double-ta...   Feb 17 2011, 09:41 PM
9146986   I'm not a big fan of the Corvair fan belt set ...   Feb 17 2011, 07:32 PM
BIGKAT_83   I'm not a big fan of the Corvair fan belt set...   Feb 17 2011, 07:42 PM
gandalf_025   I started driving Corvair turbo's in the mid 7...   Feb 17 2011, 10:34 PM
jd74914   They are known for dropping valve seats and bea...   Feb 18 2011, 07:40 AM
dion9146   I've got a funny, slightly OT story about a Co...   Feb 18 2011, 06:22 AM
Dr Evil   I have 140, tri ported heads that are going on my ...   Feb 18 2011, 06:31 AM
Don M   Built dozens of these years ago, used mostly 140hp...   Feb 18 2011, 08:51 AM
Dr Evil   I am shooting for 8.5:1, last was 8.3:1. I will po...   Feb 18 2011, 10:38 AM
Vacca Rabite   When I am done with my truck, I am considering a c...   Feb 18 2011, 10:44 AM
914rat   After reading the build thread and looking @ the p...   Feb 18 2011, 03:43 PM
KELTY360   After reading the build thread and looking @ the ...   Feb 18 2011, 06:51 PM
RJMII   I hope I'm not listed in that group. If so,...   Feb 18 2011, 05:39 PM
RJMII   Sure, it could be a good topic, if you remember ...   Feb 18 2011, 05:42 PM
vsg914   I dont know jack about a corvair, and dont care, b...   Feb 18 2011, 07:06 PM
Gearhead1432   If I end up doing a conversion, it will probably b...   Feb 18 2011, 09:16 PM
Dr Evil   If I end up doing a conversion, it will probably ...   Feb 18 2011, 10:49 PM
spankmeister7   Funny that this should come up right now because j...   Feb 19 2011, 12:59 AM
Brett W   I inspected and drove the Corvair powered car in t...   Feb 18 2011, 09:26 PM
carr914   I'm afraid the gene pool on this site is gett...   Feb 19 2011, 04:45 AM
914rat   I'm afraid the gene pool on this site is get...   Feb 19 2011, 03:54 PM
gandalf_025   If I was going to do a conversion of this type.. ...   Feb 19 2011, 06:37 AM
RJMII   the helical cut of the gears is going the wrong...   Feb 19 2011, 09:30 AM
John Jentz   the helical cut of the gears is going the wron...   Feb 19 2011, 09:47 AM
RJMII   the helical cut of the gears is going the wro...   Feb 19 2011, 10:35 AM
Dr Evil   Ya, the engine turning the wrong way will always t...   Feb 19 2011, 01:43 PM
d914   :wttc: :flag1: :D   Feb 19 2011, 03:41 PM
Gearhead1432   GM designed the Corvair engine to rotate "bac...   Feb 19 2011, 03:52 PM
Dr Evil   "After 5 years and 200 posts I guess I finall...   Feb 19 2011, 04:50 PM
pt_700   i think it's awesome the way this thread has s...   Feb 19 2011, 06:33 PM
RJMII   :beer2: Good job on the new thread. :) I...   Feb 19 2011, 08:11 PM
Gint   http://www.914world.com/bbs2/uploads/post-179-1258...   Feb 20 2011, 07:46 AM
- Lo-Fi Version Time is now: 11th July 2025 - 01:28 PM
