Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
Cool.
I asked the guy how many CFM his compressor puts out. 700cfm@170psi. (IMG:style_emoticons/default/huh.gif) Attached image(s) ![]() ![]() |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. |
Series9 |
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. The decks and doors are already gone to the painter for epoxy primer. The blaster said the same as above. The soda residue will protect bare metal for a while. The chassis will be bare for about six weeks. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Don't you need to paint something on like right away to keep it from forming rust? No actually soda inparts a rust protection and part of the reason you need to do an acid wash aferward. I had mine in the basement garage for a good year in bare metal.. Major life interfering with the fun stuff.. I only had minor flash rust and that was mostly where I touched the car. Now fla might be a tad worst on the humity front but there should be no need to rush to a primer. The decks and doors are already gone to the painter for epoxy primer. The blaster said the same as above. The soda residue will protect bare metal for a while. The chassis will be bare for about six weeks. But then the soda residue hased to be cleaned off before shooting right? If so, what is used to clean it? |
Lo-Fi Version | Time is now: 13th June 2024 - 05:34 AM |
