| jimkelly |
Oct 22 2011, 04:39 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
?? whats needed to 1.7 block and heads to install 94mm P&Cs ??
i ask because i have a set of 94mm P&Cs for sale i a potential buyer has asked me this very question. http://www.914world.com/bbs2/index.php?showtopic=148938 between you and me - i am pretty sure the block and the heads will need machining. will bigger P&Cs in a otherwise stock 1.7 bring more HP? thanks jim ** of course being in sales, i said, "hell yeah" " they will fit right in, no problem" but now i am feeling guilty about that. damn, i hate having a conscience : ) |
| VaccaRabite |
Oct 22 2011, 06:32 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,921 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Block will be fine but the cylinder registers need to be checked to see if they are collapsing.
Heads will need to be cut to accept bigger cylinders. If you have 1.8 heads they should work fine. Zach |
jimkelly ? whats needed to 1.7 block and heads to install 94mm P&Cs Oct 22 2011, 04:39 AM
jaxdream From what I've read that others more knowledge... Oct 22 2011, 07:48 AM
914rat The spigots on the case are the same on all cases.... Oct 22 2011, 12:01 PM
jimkelly thanks guys.
and i am pretty sure 1.8 heads can b... Oct 22 2011, 03:25 PM
bam914 The pin height on the 2.0L pistons is less then th... Oct 22 2011, 06:55 PM
jimkelly so it sounds like with these P&Cs.
1- any blo... Oct 25 2011, 07:10 AM
Jake Raby Detailed article on this subject can be found on m... Oct 25 2011, 07:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th October 2026 - 07:40 AM |
