| PanelBilly |
Oct 27 2011, 04:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Maybe I can post a photo to explain this better, but the side glass doesn't go high enough to seal to the rubber. I have new seals rom 914 Rubber, but the glass doesn't go high enough to fit right. I know I can adjust the window to raise higher, but then it will go above the rubber stop on top of the crome guide that holds in the wing glass. The chrome trip is held in place by a bolt in the base of the door and another inside the door. It doesn't adjust up and down. Tell me where I have this adjustment out of wack. Could it be that the rubber seal needs to be thicker. Should I have a filler between the seal and the targa top?
| 914itis |
Oct 28 2011, 10:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
IIRC it was changed in 73, so 70 -72 are the same and 73-75 are same. I am not sure what other difference the targa top would make, As Sr Andy mentioned on one of my thread, if you use a different year you will leak.
After reading that, i went and tried my friuend's 75 on my 74 and it was the same thing, No difference as far as the issue that we are having. here is the thread for the year differences http://www.914world.com/bbs2/index.php?showtopic=73129 |
| andys |
Oct 28 2011, 10:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
IIRC it was changed in 73, so 70 -72 are the same and 73-75 are same. I am not sure what other difference the targa top would make, As Sr Andy mentioned on one of my thread, if you use a different year you will leak. After reading that, i went and tried my friuend's 75 on my 74 and it was the same thing, No difference as far as the issue that we are having. here is the thread for the year differences http://www.914world.com/bbs2/index.php?showtopic=73129 Thanks for the link! Wow, I was completely un-aware there was a difference. A friend had a sanded top he gave me so I wouldn't have to sand mine. I prepped it and painted it. I'll have to check them out tonight....finger crossed (IMG:style_emoticons/default/unsure.gif) Andys |
PanelBilly Making top of door window match targa rubber Oct 27 2011, 04:34 PM
Vacca Rabite one of 4 things has happened.
1: the window is not... Oct 27 2011, 05:33 PM
7TPorsh I have this same problem...early car....hmmm :head... Oct 27 2011, 05:39 PM
ellisor3 I had the same issue. Mine was short about 1/4 inc... Oct 27 2011, 05:40 PM
Mikey914 The seals were replicated from the late OEM as the... Oct 27 2011, 06:12 PM
jim912928 Adjustment advice would be much appreciated....min... Oct 27 2011, 08:14 PM
Mikey914 Most of the adjustment is in the door. Mostly a fu... Oct 27 2011, 08:21 PM
Seaside6 I have the same issue with newly installed 914rubb... Oct 27 2011, 09:00 PM
Philip W.
I have the same issue with newly installed 914rub... Oct 28 2011, 07:41 AM
Philip W.
I have the same issue with newly installed 914rub... Oct 28 2011, 07:52 AM
ThinAir :ttiwwp:
Most of the time that's just a joke t... Oct 27 2011, 09:42 PM
ppetion This is exactly the issue that I was dealing with ... Oct 27 2011, 10:25 PM
ellisor3 If it is leaning towards the interior, the seals a... Oct 28 2011, 04:42 AM
jim_hoyland Phil,
What width 3M double sided tape are you usin... Oct 28 2011, 08:00 AM
Philip W.
Phil,
What width 3M double sided tape are you usi... Oct 28 2011, 11:02 AM
jim_hoyland
Phil,
What width 3M double sided tape are you us... Oct 28 2011, 03:34 PM
Philip W.
[quote name='Philip W.' post='1562862' date='Oct ... Oct 28 2011, 03:47 PM
r_towle
Maybe I can post a photo to explain this better, ... Oct 28 2011, 08:10 AM
andys Early car, late top, etc. What years are different... Oct 28 2011, 09:22 AM
ChrisNPDrider
Also these seals are much better with the flap,
... Oct 28 2011, 02:18 PM
Philip W.
Also these seals are much better with the flap, ... Oct 28 2011, 03:08 PM
PanelBilly The problem is with the creamsickle and now its ou... Oct 29 2011, 01:50 PM
ppetion Now I have all my windows to align correctly, I wi... Oct 30 2011, 10:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 10:02 AM |
