76 914 non-cat mint survivor, Texas dry mint 1000% orig unmolested 914 |
jasen29 |
Dec 22 2011, 03:38 PM
I'm new here ... Group: Members Posts: 0 Joined: 22-December 11 From: so cal Member No.: 13,922 Region Association: None |
almost a museum piece had it been in one! this car is about the nicest you will ever see that is unchanged , unmolested, 1000% totally stock 52k miles( totally documented with a 2 inch stack of reciepts since new) car > non cat car stored 20 yrs in climate controlled garage( up on jacks and fluids drained(don't know why he did that but oh well?) for 9 mos each year due to cold climate in South Dakota. 3 owners (* but not registerd in my name so maybe you can call it 2 on registration facts> driven less than 40 miles since I have had it 1 yr. new clutch, plugs, wires, shifter bushings and all reg maintenance> . Air force female colonel owned till 20 yrs ago , then it went up on blocks for most of the year in S. dakota. trunk has been opened maybe 50 times since new and even have the plastic foam padded cover that goes in the trunk with the mint carpet) no rust anywhere 1000% true . panels never changed mint orig paint ( with small touch up for nicks). orig rubber seals carpets seats , glass, stickers, ,, 1979 michelin tires dated 1979 that are still mint!, stock orig exhaust that is still cad plated shiney , rubber seals at firwall are all orig and not rotted out as they always are! dash is mint with no cracks anywhere and in totally orig. Has nice very, very slight patina left on purpose to show that it is non- restored, sunflower yellow ( very desired color) with buckskin int. Every thing works down to the seat belt lights and buzzers. washer bottle and all white opaque plastics still white and not yellowed. cad plating on all bolts and nuts is still fresh . paint marks on strut towers from the assemblers certification is still present and everywhere they would have marked it from new < 2.0 numbers matching motor runs mint with mint compression and logs to prove it. . see the pics to blow your mind. photo bucket pics available to serious BUYERS only. no picture collectors please >first time offered . car in so cal $20,000 serious buyers only please!!! PS be patient as i am still taking pics and posting them as I go> please notice I am at 3 pages already and am a bit new at this so I have some duplicates and screw ups!
Attached thumbnail(s) Attached image(s) |
jasen29 |
Dec 22 2011, 05:22 PM
Tom_T |
Dec 27 2011, 09:53 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/uploads/post-13922-1324596164_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-13922-1324594017.jpg) Has the rear trunk floor been replaced, or just resprayed? I think I see some overspray on the clips for the jack straps, which wouldn't have been in place at the factory spray originally. |
JeffBowlsby |
Dec 27 2011, 11:13 AM
914 Wiring Harnesses Group: Members Posts: 8,549 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads/post-13922-1324596164_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-13922-1324594017.jpg) Has the rear trunk floor been replaced, or just resprayed? I think I see some overspray on the clips for the jack straps, which wouldn't have been in place at the factory spray originally. Tom...that painted clip is welded to the trunk floor, the galv flat metal tab is on the rubber strap end...looks original to me. |
jasen29 |
Dec 27 2011, 12:52 PM
(IMG:http://www.914world.com/bbs2/uploads/post-13922-1324596164_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-13922-1324594017.jpg) Has the rear trunk floor been replaced, or just resprayed? I think I see some overspray on the clips for the jack straps, which wouldn't have been in place at the factory spray originally. Tom...that painted BRACKETT is welded to the trunk floor, the galv flat metal tab is on the rubber strap end...looks original to me. TOM AND jEFF ,, many times something is so rare to find in it's origianl state that no one remembers it that way< and then it is questioned .There are many things on this car that are that way . to me? thaT IS PART OF THE FUN !!!. REALIZING THAT WE MAY HAVE NOT KNOWN ALL ALONG AND NOW WE DO! Tom from jasen (owner) Jeff is correct that is a Mint ( original )piece of galvanized strap metal that is overlayed againist the painted brackett underneath. THE TRUNK HAS NEVER BEEN TOUCHED!. as 98% of the rest of the total volume of paint on the entire car> some very very small areas have been touched up from nicks with a tooth pick and or small pin line brush. the engine bay is mint, MINT , MINT MINT MINT MINT as well as the hell hole , door jams, trunk (frt and rear) underbody has no undercoat all IS ,MINT FROM ORIGINAL! Note: SO MUCH OF THIS CAR IS MINT ORIGINAL THAT I HAVE HAD TO DO GREAT RESEARCH AND COMPARISON TO OTHERS AND THAT MY FINDINGS ARE THAT REALLY , THIS CAR , IN ALMOST ALL WAYS , SHOULD BE USED AS THE " STANDARD " OR MODEL" TO COMPARE OTHERS WHEN IT COMES TO AUTHENTICITY AND ORIGINALITY. NOT A FASTENER, NUT , BOLT , SEAL, SCREW, BOLT , CLIP, MOULDING, GASKET, BOOT, WASHER, GLASS, VINYL, CARPET, HINGE, PLASTIC PIECE,HAS BEEN CHANGED FROM NEW |
Lo-Fi Version | Time is now: 17th June 2024 - 12:57 AM |
