steering wheel removal, horn ring removal, want to pull speedo to fix odo + wrap steering wheel |
potomacmidget |
Jan 14 2012, 11:52 AM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Hi All,
My odometer and trip odometer are working intermittently, so I guess I need to pull the gauge and see if I am gutsy enough to disassemble the gauge via the pellican article (or send to a fellow forum member for repair?) To do this I guess I need to pull the steering wheel (first the horn ring). I see in the Haynes manual I am supposed to turn the horn ring CCW, however I don't know if that means an 1/8 of a turn then it pulls off, or does it have to spin multiple times to come off? Don't want to screw up the horn contact wire since my horn actually works. Then wanted to pull the steering wheel to see if I could sew a leather cover on. Any nightmares with pulling the steering wheel? The wheel on my MG Midget comes off very easy but that car is seriously primitive compared to the 914. Any advice appreciated. thanks Reg |
struckn |
Jan 14 2012, 05:51 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
I just pulled my steering wheel today. I'm replacing my ingnition switch.
I used this Pelican Tech Artical fully describs pulling the wheel nicely. The address below is miss leading but it takes you right to it. http://www.pelicanparts.com/techarticles/9...ooler_seals.htm If you want a quick way to cover your steering wheel I bought the universal simulated black leather one at the the Parts Store and then used CY Super glue to glue the seam together all the way around except at the spokes and with out glueing it to the wheel it's self. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:40 PM |
