> Shock options for track cars, Give me your opinions
nine14cats
post May 17 2004, 01:44 PM
Bill Pickering -- 914-6 GT aka....Leeloo
Hi Gang,
I'm currently running Bilstein's all around on my track car. No special valving. Right out of the box.
If we were to assume the current set up at the bottom and the JWE Fox shocks at the top, what are my options in between?
My current car setup:
Front =
23mm solid t-bars
27mm Smart racing AR bar
911T struts, calipers, brakes
turbo tie rods
Bilstein shocks
Rear =
350lbs to 450lbs springs (depending upon track or application)
adjustable perches
Bilstein shocks
944 calipers and brakes
I will be going to bigger brakes all around, so I won't have the 911T struts much longer.
What are my shock options and approx. costs?
i.e. low end $500, Fox shocks $4400....
We run this car at Thunderhilll, Laguna Seca, Sears, Buttonwillow.
Thanks,
Bill P.
TimT
post May 21 2004, 02:37 PM
retired
Koni now makes an adjustable front strut for 911's. Im having my struts converted, In the rear I use the Koni 3012, it weighs in at 3 lbs, and is adjustable for both compression and rebound..
Look Here
nine14cats   Shock options for track cars   May 17 2004, 01:44 PM
seanery   wasn't Smart Racing supposedly working on maki...   May 17 2004, 02:59 PM
ChrisReale   SmartRacing and affordable in the same sentence, S...   May 17 2004, 03:13 PM
seanery   do you guys remember? there was an article in exce...   May 17 2004, 03:22 PM
brant   I remember sean... (probably still out of my price...   May 17 2004, 03:34 PM
Jeroen   Yep, those are the Fox-shocks mentioned above I th...   May 17 2004, 03:35 PM
nine14cats   I believe they are the $4400 shocks and strut...   May 17 2004, 03:35 PM
J P Stein   Bilstein will revalve yours for 65 bucks a pop. Wo...   May 17 2004, 05:55 PM
TimT   :agree: let Bilstein valve your shocks appropria...   May 17 2004, 06:55 PM
campbellcj   If you are going to replace the front strut assemb...   May 17 2004, 10:41 PM
seanery   Bill, on the plane to Houston I was reading my new...   May 19 2004, 02:40 PM
Mueller   that's each :) I held/touched a set of those ...   May 19 2004, 02:50 PM
seanery   I was afraid to go look to see if that was each/pa...   May 19 2004, 02:54 PM
Jeroen   If those are EACH, than I'll scratch them of m...   May 19 2004, 03:16 PM
campbellcj   I'd be suprised if the 1200 is "each". IMHO t...   May 19 2004, 11:04 PM
Brad Roberts   For those of you who said: "have custom valved sho...   May 19 2004, 11:15 PM
nine14cats   This board rocks! :trophy: Look at all of ...   May 19 2004, 11:21 PM
J P Stein   Gud idea, Brad. Spend $5-6K for some shox......   May 20 2004, 02:47 AM
Jeroen   I checked with Kanna Motorsports a little while ba...   May 20 2004, 06:33 AM
Bleyseng   Ya-roon, How is the 914 project coming? Any pro...   May 20 2004, 07:33 AM
Brad Roberts   JP, It takes one time at a local venue to set the...   May 20 2004, 10:48 PM
Rob Ways   I want to go to Konis because I want to go from ha...   May 20 2004, 11:03 PM
J P Stein   Brad: I ran street tires. The only thing I learne...   May 21 2004, 01:33 AM
Thorshammer   Okay Okay! I'll chime in! The fox is ...   May 21 2004, 01:14 PM
itsa914
  May 21 2004, 01:35 PM
Thorshammer   Sorry Would 'nt accept my JPG file for some re...   May 21 2004, 02:12 PM
Thorshammer   Try this!   May 21 2004, 02:14 PM
TimT   Koni now makes an adjustable front strut for 911...   May 21 2004, 02:37 PM
campbellcj   The problem with the high-end adjustables (beside...   May 21 2004, 02:59 PM
nine14cats   How much? :D Looks like I'll be saving for a...   May 21 2004, 03:14 PM
Jeroen   Those double adjustable Koni's look about righ...   May 21 2004, 07:36 PM
nine14cats   Wow...those Koni's look good too! I...   May 21 2004, 09:36 PM
- Lo-Fi Version Time is now: 15th July 2025 - 04:07 AM
