> GT engine lid and rain trays, Do you just go without?
Rbcm2005
post Aug 28 2012, 12:03 PM
So we are interested in installing a GT engine lid on our project because we like the look and it gets HOT where we are so thinking that the extra ventilation would help. However... it also rains here and we are guessing that Porsche didn't go with rain trays just for the fun of it.
What is everyone doing with regard to their rain trays when they install these GT lids?
CHEERS!
(IMG:style_emoticons/default/drunk.gif)
ottox914
post Aug 28 2012, 02:27 PM
The glory that once was.
GT lid, no rain tray, big honk'n intercooler between 2 ITB'S. IAT'S go up by 10-15 degrees from the lid being on vs being off and totally open. I wouldn't have thought it would make that much difference, but it does.
JmuRiz
post Aug 29 2012, 09:01 AM
QUOTE(ottox914 @ Aug 28 2012, 12:27 PM) *
Otto, if it's OK to put a turbo intercooler there under the GT-style lid...would it be OK to put an external oil-cooler under there to help keep a 2.7/6 cooler...along with the standard on-engine cooler.
On-topic: I'll just try not to drive mine in the rain...and will probably use a stock-ish airbox on my conversion if I decide to go carbs.
ottox914
post Aug 30 2012, 06:56 AM
QUOTE(JmuRiz @ Aug 29 2012, 10:01 AM) *
I'm no expert on a 6 cyl install, but I would think no on the engine bay oil cooler. Here's why. I know of a guy who did PCA track days in a bone stock 2.0 914. He had engine bay oil coolers (2) mounted to the far left and far right under a open single grill lid, no rain tray. And he cooked several motors before going to a front mount. This could be an extreme example, but at speed he was discharging enough heat from the coolers, the engine fan took it in and blew it over the cyls, causing more heat in the oil, more heat into the engine compartment, and the circle never ends. There must be a reason there is tin to separate the upper (cooling) and lower (hot exhaust) sections of our motors, 4 or 6 cyl. I think the intercooler works for me because the incoming air from the turbo is not nearly as hot as the oil, so not as much heat added to the system. The open grill GT lid, and the fact that the car is used for autocross, (shorter runs) help too. Len's heads that flow like CRAZY, and a much better than stock cam help keep temps down and stable. I have noticed that even with the open GT lid, my intake air temps run 10-15 degrees higher with the lid in place VS running with no lid at all. So even with all that mesh, less cooling air is getting in, and less hot air is getting out. I haven't tried to add some ducting from the IC to the lid, to better direct air flow. I may have to try that some day. The IC does have a plenum and sucker fan on the back of it, to pull as much air thru it as possible. Not sure if you would be considering this for your oil cooler set up or not. Without the plenum and fan, I don't think there would be nearly as much flow thru the cooler. I've been thinking of a removable, tall, 1980's F1 style scoop that I can mount on the targa bar when I'm at an autoX to provide some ram air intake for the intercooler. It'd look a little silly on a street car, but would be kinda funny on sundays... Could be a fun winter project.
Rbcm2005   GT engine lid and rain trays   Aug 28 2012, 12:03 PM
monkeyboy   They don't drive their cars in the rain...   Aug 28 2012, 12:14 PM
Eric_Shea   No rain tray. Are you using a 911 motor? If so, ...   Aug 28 2012, 12:15 PM
mrbubblehead   i have a gt lid. carbs and rain hats. honestly, wh...   Aug 28 2012, 12:22 PM
Elliot Cannon   i have a gt lid. carbs and rain hats. honestly, w...   Aug 29 2012, 11:49 AM
rstover   i have a gt lid. carbs and rain hats. honestly, w...   Aug 30 2012, 07:04 PM
ConeDodger   No driving in the rain. But I did use rain hats wh...   Aug 28 2012, 01:50 PM
ottox914   GT lid, no rain tray, big honk'n intercooler b...   Aug 28 2012, 02:27 PM
JmuRiz   GT lid, no rain tray, big honk'n intercooler ...   Aug 29 2012, 09:01 AM
ottox914   GT lid, no rain tray, big honk'n intercooler...   Aug 30 2012, 06:56 AM
Vacca Rabite   No raintray on mine. Don't drive in the rain i...   Aug 28 2012, 03:08 PM
RON S.   They don't drive their cars in the rain... ...   Aug 28 2012, 04:42 PM
stuttgart46   I didn't drive mine in the rain but I got stuc...   Aug 29 2012, 08:53 AM
SLITS   No rain tray ... /6 conversion ... driven in rain ...   Aug 29 2012, 09:51 AM
MoveQik   No rain tray ... /6 conversion ... driven in rain...   Aug 29 2012, 11:53 AM
Scott S   A few years ago we had a major rain storm hit half...   Aug 29 2012, 10:25 AM
kfish914   I am working on a 2.7 conversion and I plan on mak...   Aug 29 2012, 11:34 AM
Eric_Shea   Nice trailer sister...   Aug 29 2012, 09:50 PM
MoveQik   Nice trailer sister... That was so 2010. I flat...   Aug 30 2012, 06:53 AM
MikeSpraggi   No rain tray. I have and will drive it on the tra...   Aug 29 2012, 09:57 PM
pete000   My 70 914-6 No rain tray. My 74 914-4 Rain tray r...   Aug 29 2012, 11:37 PM
pcar916   No room for a rain tray, daily driver, no worries,...   Aug 30 2012, 10:15 AM
gothspeed   .....................................................   Aug 31 2012, 04:19 PM
seanery   914 Umbrella Perry makes these 9146986 here in t...   Aug 30 2012, 07:12 PM
rstover   914 Umbrella Perry makes these 9146986 here in ...   Aug 30 2012, 07:19 PM
mrbubblehead   i use my umbrella daily.   Aug 30 2012, 07:23 PM
larryM   nobody mentions wet distibutor problem - it CAN ha...   Aug 31 2012, 02:36 PM
mrbubblehead   nobody mentions wet distibutor problem - it CAN h...   Aug 31 2012, 02:49 PM
jsayre914   i drive my 2.0 4 in the rain and snow 365 days a y...   Aug 31 2012, 04:39 PM
JmuRiz   That fender-well cooler is neat, hadn't though...   Aug 31 2012, 07:07 PM
- Lo-Fi Version Time is now: 1st August 2025 - 03:05 AM
