Snorkel Tube wiring harness GB $28 each, These will be $45 after the GB - GB ends June 16th |
Mikey914 |
Dec 20 2012, 01:28 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A great part to have if you need one. I was tapped to make these awhile ago, and there looked like there was some interest in doing these. I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. The flanges will be slightly larger to allow for a tighter fit. So there will be some improvements, but look pretty stock. They should be easier to install than stock. I try to make most of my stuff as close to factory as possible where it makes sense, and I think factory had it right as one piece.
Attached thumbnail(s) |
SirAndy |
Dec 20 2012, 02:04 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. Can you make a version that is longer than stock for those of us with /6 conversions using aftermarket bulkhead motor mounts? The stock ones usually rip to pieces when you try to stretch them to fit around the new mounts. (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1165172769.jpg) |
JeffBowlsby |
Dec 20 2012, 02:57 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. Can you make a version that is longer than stock for those of us with /6 conversions using aftermarket bulkhead motor mounts? The stock ones usually rip to pieces when you try to stretch them to fit around the new mounts. (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1165172769.jpg) For these special applications, how about using two snorkels, cutting off one end of each and just nesting (overlapping) them? In addition to soapy water, glycerin is a great wire pulling lube. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:40 AM |
