Why is converting to a 911 5-lug suspension better than drilling the 914 rotors?, Are the 911 bits really better? |
billh1963 |
Feb 18 2013, 07:16 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I'm thinking of converting the Zambezi Green car over to 5 lug Fuchs (no flares) and am trying to understand if 5 lug suspension pieces are really necessary versus just drilling the current hubs?
This will not be a track or autocross car...simply a driver. I actually do have the parts to convert (struts and stuff from a 1970 911); however, I was just wondering if there is any reason to actually make the conversion for a street driver. Other than the benefit of getting the bigger 911 brakes on the front, is there a strength, reliability, adjustability, etc. issue? Thoughts? |
Eric_Shea |
Feb 18 2013, 11:17 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less.
If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Feb 18 2013, 01:39 PM
Custom Member Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less. If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) What would the price be for your parts? the Cheap-elite option. Front rotors (drilled 5 lug) Rear rotors (drilled 5 lug) Rear hubs (drilled with extra boss applied) I would hold off on studs until I figure out what wheels and spacers I will use. Rich |
KENNY |
Feb 18 2013, 02:17 PM
Member Group: Members Posts: 142 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None |
Lots of things to weigh but, as stated early on, drilling the hubs and rotors can net you a very safe solution for much less. If you go the factory route you'll be in for struts, inserts, rotors and new calipers. Check out my 5-lug conversion thread and it should weigh out all of the options. http://www.914world.com/bbs2/index.php?showtopic=105728 Signed... The Fish Guy (not sure what that means but if Jeff said it then...) (IMG:style_emoticons/default/confused24.gif) What would the price be for your parts? the Cheap-elite option. Front rotors (drilled 5 lug) Rear rotors (drilled 5 lug) Rear hubs (drilled with extra boss applied) I would hold off on studs until I figure out what wheels and spacers I will use. Rich If you don't mine I will be interest in price two .i need same thing but whit studs for 6x15 wheels |
Lo-Fi Version | Time is now: 17th June 2024 - 12:42 AM |
