| rhd914 |
Apr 12 2013, 12:45 AM
Newbie ![]() Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
Hi All, I am slowly converting my '73 2.0 to a 3.2. I have the engine and gearbox in, oil lines, gearchange and clutch pretty well sorted. I am now turning my attention to the intake system. I am using the Factory DME.
What I need to see is how others have done the air intake to the throttle body? The Factory rubber elbow sits up a little too high. Also, where and how did you mount and connect the air flow meter? If anyone has some photo's, can you post them please, I'd like to see them. It would be a help to me. Thanks Geoff (IMG:style_emoticons/default/smile.gif) |
| Steve |
Apr 12 2013, 08:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,033 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Click on my name and go to my blog for my pictures. I used a PVC pipe from Home Depot and extended the air flow meter. This allowed me to keep the stock air cleaner. It takes a little more room, but its waterproof. I might go back to a cone filter like the other guys and make a water shield. I bet K&N already makes one
rhd914 3.2 conversion Apr 12 2013, 12:45 AM
Hi All, I am slowly converting my '73 2.0 to... Apr 12 2013, 03:22 AM
rhd914 That sounds great, I'll try that in the mornin... Apr 12 2013, 04:49 AM
mepstein From what I've seen you add a PVC extension to... Apr 12 2013, 05:39 AM
phillstek Here's mine. Linkage from throttle body goes t... Apr 12 2013, 06:10 AM
MoveQik Mine is about the same... Apr 12 2013, 07:22 AM
Madswede Hmmm, my 3.2 doesn't have one of those. :conf... Apr 12 2013, 01:38 PM
AZ914
Hmmm, my 3.2 doesn't have one of those. :con... Apr 12 2013, 01:55 PM
AZ914 Mine is exactly the same as Mike's (MOVQIK) ab... Apr 12 2013, 01:56 PM
jim912928 I have pictures if you search my screen name. I d... Apr 12 2013, 05:12 PM
tomeric914 Flipped. Check page 3 on my build thread in my si... Apr 13 2013, 10:05 PM
rhd914 That's great thanks for the reply's. Apr 14 2013, 12:03 AM
McMark Something a little different. Keeps the stock air... Apr 14 2013, 09:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 02:04 AM |
