> Fuel Rails, Any alternatives?
newdeal2
post Jul 14 2004, 03:20 PM
Unregistered
Are there any good replacements for the stock FI rails? My stock ones look a bit crude.
These are on eBay but I think they are overkill...yes?
Dave_Darling
post Jul 15 2004, 06:00 PM
914 Idiot
QUOTE(newdeal2 @ Jul 15 2004, 09:46 AM)
Just add one with a barbed T after the fuel pressure regulator .
Not with the stock FI setup... You want to T into something "downstream" of the fuel pump, and "upstream" of the pressure regulator.
Pressure regulator analogy time--
Picture a garden hose. Turn it on and watch the water come out of the end. There's some pressure in the hose, right, but not a whole lot because you're letting it out the end. Now, put your thumb over the end. What happens to the pressure inside the hose? It goes up. Now, let your thumb just a little tiny bit off the hose. You get a spray of water, of course, but what happens to the pressure inside the hose? It drops, by some amount that partly depends on how much of a gap you leave.
OK, now picture the water supply as being the fuel pump. The garden hose is the "high pressure loop" of your fuel system (including both fuel rails). Your thumb is the pressure regulator.
The regulator is a spring-loaded valve. When the pressure inside the rail is high enough, it pushes the valve open and bleeds off enough fuel to drop the pressure back down to the set amount. It's as if you moved your thumb to make a larger or smaller opening according to a pressure gauge on the garden hose. (The L-jet one has a vacuum diaphragm as well as a spring, and the fuel has to overcome the manifold pressure as well as the spring force in order to bleed off into the return line. But it's a very similar idea.)
--DD
newdeal2   Fuel Rails   Jul 14 2004, 03:20 PM
newdeal2   try this... http://cgi.ebay.com/ebaymotors/ws/eBa...   Jul 14 2004, 03:22 PM
Mueller
  Jul 14 2004, 04:40 PM
Mark Henry   Save you coin, the stock ones work fine. Their cl...   Jul 15 2004, 08:22 AM
newdeal2   I have an in line gauge already. My question was ...   Jul 15 2004, 08:50 AM
mike_the_man
  Jul 15 2004, 09:26 AM
newdeal2
That's probably what I will do Thanks   Jul 15 2004, 09:44 AM
PorscheTom   Along the lines fuel pressure gauges, how and wher...   Jul 15 2004, 10:58 AM
newdeal2   Just add one with a barbed T after the fuel pressu...   Jul 15 2004, 11:46 AM
Eric_Shea
  Jul 15 2004, 02:48 PM
mike_the_man   I sent them an email asking if they had any dyno r...   Jul 15 2004, 04:03 PM
newdeal2   Since I have had no response on my other subject ...   Jul 15 2004, 04:41 PM
Dave_Darling   ...   Jul 15 2004, 06:00 PM
TimT   Marren Fuel Injection can supply fuel rails, clean...   Jul 15 2004, 06:01 PM
newdeal2   Back to dave's comment. My pressure gauge was ...   Jul 15 2004, 06:26 PM
newdeal2   So what Dave is saying...now that I have read it a...   Jul 15 2004, 06:33 PM
newdeal2   Tim T Thanks for the source. I am sending my fuel...   Jul 15 2004, 07:06 PM
SpecialK   This may explain what Dave is trying to "lay down"...   Jul 15 2004, 07:13 PM
newdeal2   The gauge was located just above the regulator in...   Jul 15 2004, 07:19 PM
SpecialK   Should work correctly then ;)   Jul 15 2004, 07:25 PM
StratPlayer   This is where I mounted my fuel pressure gauge wit...   Jul 16 2004, 10:01 AM
Eric_Shea   One would think you could mount them in both locat...   Jul 16 2004, 02:19 PM
Eric_Shea   What kind of car is that Jim? :confused: :D ...   Jul 16 2004, 02:20 PM
mike_the_man   When I add one for adjusting or checking the fuel ...   Jul 16 2004, 04:11 PM
Dave_Darling   Mike, your understanding is correct. The "after t...   Jul 16 2004, 05:12 PM
Curvie Roadlover   Is that a steel braided hose from the airbox to th...   Jul 16 2004, 05:15 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 01:23 PM
