| shawn914 |
Nov 21 2013, 10:09 PM
Member ![]() ![]() Group: Members Posts: 185 Joined: 13-February 12 Member No.: 14,126 Region Association: MidAtlantic Region |
Need to remove these wheel studs. I've tried a C-clamp, without success. Thought about a BFH but that can't be right (right?). Any ideas welcome - thanks.
Thanks Shawn (I did a search with the google app, no threads located) ![]() |
| shuie |
Nov 22 2013, 08:30 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
The fronts can be pressed out pretty easily in a bench vice. Unless the rears are welded in, you should be able to put a steel lug nut on them and whack them out with a hammer.
shawn914 How to remove wheel stud Nov 21 2013, 10:09 PM
Mike Bellis 20 ton press... Nov 21 2013, 10:16 PM
Elliot Cannon
20 ton press...
Or a BFH. I used one and it wor... Nov 21 2013, 10:22 PM
Spoke
20 ton press...
:agree:
Your local automotive... Nov 21 2013, 10:23 PM
messix u gotta compressor and a air chisel ?
use the dri... Nov 21 2013, 10:29 PM
Montreal914 Just did mine with the press yesterday, piece of c... Nov 21 2013, 10:36 PM
914dave Shawn
I have a 12 ton press if you want to bring ... Nov 22 2013, 05:03 AM
jimkelly check out post #138
http://www.914world.com/bbs2/... Nov 22 2013, 05:18 AM
shawn914 All - Thanks for the suggestions, I don't have... Nov 22 2013, 05:27 AM
Rleog Here's a link showing a tool available at Harb... Nov 22 2013, 08:52 AM
Krieger You could try heating them in an oven for a while ... Nov 22 2013, 09:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:23 PM |
