> 3rd Brake light with pulse strobe, My $5 buck 3rd brake light with $5 strobe
dangrouche
post Jun 15 2013, 01:04 PM
dangrouche
How many of you are paranoid of being rear ended? I certainly am. Here's my installation of a 24-LED brake light that I installed with a few bits from my workbench. I got this 24-LED from a Bang Good.com. That website gives free shipping. The current model is on sale for $5.19 and that model is SKU010514. I bought the 24-LED version, which they no longer stock and it cost me $4.55. Its $7.49 at AMAZON. NO RELAY OR OTHER ELECTRICAL PARTS NEEDED. I know I have seen these in the FLAPS for at least double or triple that. Anyway, as long as you can wait a couple of weeks, you can either buy it there or go to the FLAPS. I finished the install last night. This morning when I went to open the rear trunk, I see that I should installed the light closer to the rear window. Almost tore the thing off! Pic one shows the wrong way to do it. Pic two shows the wiring from the left rear tail light housing. I put on brass spades (get from FLAPS) that sisters the existing connections and no OEM wiring was cut or spliced to do this install. Pic three shows routing for two leads into the engine compartment into the engine compartment. Pic four shows how I drilled the plastic with a 1/8" bit and threaded the wiring. I also used speed clips (from car speaker install kits) and you see the galvanized metal in the pic. I stuck a patch of velcro as a vibration pad. Pic five shows the velcro in place. I also added a flat washer and a lock washer when I screwed it into place. Pic six shows the completed installation. I also covered the entire wiring in small plastic tubing and zip tied everything in place, leaving a large loop of wire so the engine lid can be opened. I considered installing this under the targa bar, but routing the wire would have been too much work and I did not want to use the double sided foam tape that came with the light. This install can quickly undone with a pair of dykes in a few minutes.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
7TPorsh
post Dec 17 2013, 01:48 PM
7T Porsh
My light took about 2 1/2 weeks; came in a bubble pack bag that would cost me $4 at Staple. Amazed they can design, build, pack and ship this across the world for less than a pound of peanuts.
I bought the 24 LED version; they had a 32 version too
dangrouche   3rd Brake light with pulse strobe   Jun 15 2013, 01:04 PM
Bartlett 914   I think it would look better forward of the grill   Jun 15 2013, 01:40 PM
r_towle   Cool job.   Jun 15 2013, 03:57 PM
turk22   really like how did the wiring, with nothing cut.....   Jun 15 2013, 04:06 PM
bandjoey   So does it work??? Show me the RED!   Jun 15 2013, 08:01 PM
dangrouche   okay, no one around to help me step on the pedal, ...   Jun 15 2013, 11:44 PM
dangrouche   I added a $5 strobe flasher to my 3rd brake l...   Oct 1 2013, 08:20 PM
RickS   Nice work and yes I am just as paranoid adding a...   Oct 1 2013, 10:15 PM
gothspeed   Nice work and yes I am just as paranoid adding ...   Dec 16 2013, 10:05 PM
anderssj   Nice work, and thanks for the tip on the LSC-100A ...   Oct 2 2013, 06:56 PM
RickS   Nice work, and thanks for the tip on the LSC-100A...   Oct 2 2013, 10:32 PM
76-914   I like the strobe controller. Look out Wheelen.   Oct 2 2013, 07:09 PM
kid914   :idea: I wonder if the strobe module would work w...   Oct 2 2013, 07:13 PM
914forme   Flashing lights are restricted to emergency vehicl...   Oct 3 2013, 10:00 AM
Cairo94507   Stephen I would like to see your Ford GT 3rd brake...   Oct 4 2013, 07:50 AM
914forme   Stephen I would like to see your Ford GT 3rd brak...   Oct 4 2013, 11:06 AM
Cairo94507   That is what Scotty is going to do to incorporate ...   Oct 4 2013, 10:42 PM
Nürburg Nomad   That is what Scotty is going to do to incorporate...   Oct 5 2013, 09:48 AM
7TPorsh   I had an extra...10 minutes...to this and did it w...   Dec 16 2013, 02:56 PM
7TPorsh   RE: 3rd Brake light with pulse strobe   Dec 16 2013, 02:56 PM
Rleog   Well, I'll be amazed if this purchase goes thr...   Dec 16 2013, 07:30 PM
scott_in_nh   Well, I'll be amazed if this purchase goes th...   Dec 18 2013, 11:16 AM
porsche913b_sp   banggood.com, sounds like a porno store :D whats ...   Dec 16 2013, 08:28 PM
dangrouche   you get the pulse module from superbrightleds.com ...   Dec 16 2013, 09:47 PM
pjhaun   Here is what I did to mine. I used a similar fla...   Dec 16 2013, 10:57 PM
7TPorsh   Here is what I did to mine. I used a similar fl...   Dec 17 2013, 01:50 PM
falcor75   Here is what I did to mine. I used a similar fl...   Dec 18 2013, 09:37 AM
pjhaun   [quote name='pjhaun' post='1971513' date='Dec 17 ...   Dec 18 2013, 09:13 PM
boxsterfan   Here is what I did to mine. I used a similar fl...   Dec 18 2013, 11:25 AM
pjhaun   [quote name='pjhaun' post='1971513' date='Dec 16 ...   Dec 18 2013, 09:00 PM
7TPorsh   My light took about 2 1/2 weeks; came in a bubble ...   Dec 17 2013, 01:48 PM
computers4kids   The 3rd brake lights from a Corvette 1986 to 1990 ...   Dec 18 2013, 08:43 AM
bandjoey   24" led strip at autozone $20. Used mine...   Dec 18 2013, 06:27 PM
Rleog   I ordered the 32 LED brake light on 12/16, paid ...   Jan 2 2014, 03:48 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 12:54 AM
