| dangrouche |
Jun 15 2013, 01:04 PM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
How many of you are paranoid of being rear ended? I certainly am. Here's my installation of a 24-LED brake light that I installed with a few bits from my workbench. I got this 24-LED from a Bang Good.com. That website gives free shipping. The current model is on sale for $5.19 and that model is SKU010514. I bought the 24-LED version, which they no longer stock and it cost me $4.55. Its $7.49 at AMAZON. NO RELAY OR OTHER ELECTRICAL PARTS NEEDED. I know I have seen these in the FLAPS for at least double or triple that. Anyway, as long as you can wait a couple of weeks, you can either buy it there or go to the FLAPS. I finished the install last night. This morning when I went to open the rear trunk, I see that I should installed the light closer to the rear window. Almost tore the thing off! Pic one shows the wrong way to do it. Pic two shows the wiring from the left rear tail light housing. I put on brass spades (get from FLAPS) that sisters the existing connections and no OEM wiring was cut or spliced to do this install. Pic three shows routing for two leads into the engine compartment into the engine compartment. Pic four shows how I drilled the plastic with a 1/8" bit and threaded the wiring. I also used speed clips (from car speaker install kits) and you see the galvanized metal in the pic. I stuck a patch of velcro as a vibration pad. Pic five shows the velcro in place. I also added a flat washer and a lock washer when I screwed it into place. Pic six shows the completed installation. I also covered the entire wiring in small plastic tubing and zip tied everything in place, leaving a large loop of wire so the engine lid can be opened. I considered installing this under the targa bar, but routing the wire would have been too much work and I did not want to use the double sided foam tape that came with the light. This install can quickly undone with a pair of dykes in a few minutes.
Attached thumbnail(s) |
| pjhaun |
Dec 16 2013, 10:57 PM
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Here is what I did to mine. I used a similar flasher. It had 2 wires in and 2 wires out. I think the one I bought was designed for a motorcycle.
http://youtu.be/fq0o2fBhSaA |
| boxsterfan |
Dec 18 2013, 11:25 AM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Here is what I did to mine. I used a similar flasher. It had 2 wires in and 2 wires out. I think the one I bought was designed for a motorcycle. http://youtu.be/fq0o2fBhSaA Where did you get the long strip? |
dangrouche 3rd Brake light with pulse strobe Jun 15 2013, 01:04 PM
Bartlett 914 I think it would look better forward of the grill Jun 15 2013, 01:40 PM
r_towle Cool job. Jun 15 2013, 03:57 PM
turk22 really like how did the wiring, with nothing cut..... Jun 15 2013, 04:06 PM
bandjoey So does it work???
Show me the RED! Jun 15 2013, 08:01 PM
dangrouche okay, no one around to help me step on the pedal, ... Jun 15 2013, 11:44 PM
dangrouche I added a $5 strobe flasher to my 3rd brake l... Oct 1 2013, 08:20 PM
RickS
Nice work and yes I am just as paranoid adding a... Oct 1 2013, 10:15 PM
gothspeed
Nice work and yes I am just as paranoid adding ... Dec 16 2013, 10:05 PM
anderssj Nice work, and thanks for the tip on the LSC-100A ... Oct 2 2013, 06:56 PM
RickS
Nice work, and thanks for the tip on the LSC-100A... Oct 2 2013, 10:32 PM
76-914 I like the strobe controller. Look out Wheelen. Oct 2 2013, 07:09 PM
kid914 :idea: I wonder if the strobe module would work w... Oct 2 2013, 07:13 PM
914forme Flashing lights are restricted to emergency vehicl... Oct 3 2013, 10:00 AM
Cairo94507 Stephen I would like to see your Ford GT 3rd brake... Oct 4 2013, 07:50 AM
914forme
Stephen I would like to see your Ford GT 3rd brak... Oct 4 2013, 11:06 AM
Cairo94507 That is what Scotty is going to do to incorporate ... Oct 4 2013, 10:42 PM
Nürburg Nomad
That is what Scotty is going to do to incorporate... Oct 5 2013, 09:48 AM
7TPorsh I had an extra...10 minutes...to this and did it w... Dec 16 2013, 02:56 PM
7TPorsh RE: 3rd Brake light with pulse strobe Dec 16 2013, 02:56 PM
Rleog Well, I'll be amazed if this purchase goes thr... Dec 16 2013, 07:30 PM
scott_in_nh
Well, I'll be amazed if this purchase goes th... Dec 18 2013, 11:16 AM
porsche913b_sp banggood.com, sounds like a porno store :D whats ... Dec 16 2013, 08:28 PM
dangrouche you get the pulse module from superbrightleds.com ... Dec 16 2013, 09:47 PM
7TPorsh
Here is what I did to mine. I used a similar fl... Dec 17 2013, 01:50 PM
falcor75
Here is what I did to mine. I used a similar fl... Dec 18 2013, 09:37 AM
pjhaun
[quote name='pjhaun' post='1971513' date='Dec 17 ... Dec 18 2013, 09:13 PM
pjhaun
[quote name='pjhaun' post='1971513' date='Dec 16 ... Dec 18 2013, 09:00 PM
7TPorsh My light took about 2 1/2 weeks; came in a bubble ... Dec 17 2013, 01:48 PM
computers4kids The 3rd brake lights from a Corvette 1986 to 1990 ... Dec 18 2013, 08:43 AM
bandjoey 24" led strip at autozone $20. Used mine... Dec 18 2013, 06:27 PM
Rleog I ordered the 32 LED brake light on 12/16, paid ... Jan 2 2014, 03:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:53 AM |
