> Electric washer with wipers activation, Nice additions to SirAndy's tutorial - now with PICTURES
Valy
post Mar 22 2011, 03:53 PM
I've been struggling with my washer for a long time. I liked the idea of electric washer but had the simple wiper switch that doesn't have the additional contact for the intermittent position and can't stand the idea to drill a hole for the button in my nice dash.
I'm also a CSOB (aren't we all?) so won't buy the $100 new wiper switch.
For those in need, here is the link to Andy's tutorial.
http://www.914world.com/specs/tech_el_washer.php
I started from there but wanted to make my wiper switch trigger it and start the wipers at the same time (IMG:style_emoticons/default/smile.gif)
How do I do it simple, "original" and cheap?
Here it comes:
First, I need to trigger the wipers when the washer pump works.
You don't need the intermittent relay to trigger the wipers when you trigger the pump. In fact, the original intermittent relay combined with the washer pump like Andy suggested may cause some unwanted electrical gremlin due to the switch wiring. So, if you're like me and only want the wipers to trigger once when you activate the pump, all you need is a regular relay! ($2 on ebay with the socket and wires)
Here is the schematics of the modified circuit that I used:
I used the Brown/Black wire that was existent in my car to trigger the relay and the washer pump.
I also modified the wiper switch and added the missing "53c" contact. It's a pretty simple modification but don't have the pictures right now to show as the switch is already on the car.
I'll add the pictures if there is enough interest in this thread.
Valy
post Jun 18 2014, 02:30 PM
I finally installed that switch. I was planning to take it apart and fix the issue but it fitted in aside was and worked well.
The new switch is a bit more rigid than the old swf but that's because it's new. Not a real issue.
Make sure the pump sits lower than the water reservoir or else you'll need to prime the pump every time you use it and it will overheat and burn it eventually.
If you go through all the trouble of installing the pump, wire the programable intermittent relay as I did. You won't regret it.
Valy   Electric washer with wipers activation   Mar 22 2011, 03:53 PM
Eric_Shea   Please do.   Mar 22 2011, 04:29 PM
SirAndy   Please do. :agree:   Mar 22 2011, 05:06 PM
Valy   Here are the pictures: I made a copper tab that c...   Mar 22 2011, 07:46 PM
Valy   More:   Mar 22 2011, 07:47 PM
bigkensteele   Nicely done!   Mar 22 2011, 08:37 PM
Eric_Shea   :agree: What's your address? I'm sending ...   Mar 23 2011, 11:12 AM
Valy   :agree: What's your address? I'm sending...   Mar 23 2011, 12:06 PM
ChrisNPDrider   SWEET :beer2: I am doing my interior rustoration...   Mar 23 2011, 01:23 PM
bandjoey   SWEET :beer2: I am doing my interior rustoratio...   Mar 23 2011, 01:47 PM
Valy   SWEET :beer2: I am doing my interior rustoratio...   Mar 23 2011, 05:47 PM
Bartlett 914   There is some discussion on this thread about inte...   Mar 23 2011, 03:41 PM
Valy   There is some discussion on this thread about int...   Mar 23 2011, 05:13 PM
HalfMoon   [quote name='Bartlett 914' post='1448170' date='M...   Jun 18 2014, 01:41 PM
plymouth37   Nice work!   Mar 23 2011, 04:12 PM
Valy   Nice work! Thanks! Getting this from yo...   Mar 23 2011, 05:19 PM
jt914-6   Not to hijack but I can offer a wiper switch that ...   Mar 23 2011, 06:53 PM
Valy   Update: I've added a programmable intermitten...   Aug 22 2011, 08:08 AM
Valy   I finally installed that switch. I was planning t...   Jun 18 2014, 02:30 PM
HalfMoon   I finally installed that switch. I was planning ...   Jun 18 2014, 03:34 PM
HalfMoon   I finally installed that switch. I was planning...   Jun 19 2014, 12:00 PM
Valy   Don't worry, I understand your situation. I ha...   Jun 19 2014, 04:39 PM
HalfMoon   Don't worry, I understand your situation. I h...   Jun 19 2014, 05:14 PM
Valy   It's all plug and play except the new wire (A)...   Jun 19 2014, 09:59 PM
HalfMoon   It's all plug and play except the new wire (A...   Jun 19 2014, 11:42 PM
HalfMoon   It's all plug and play except the new wire (A...   Jul 4 2014, 11:53 AM
- Lo-Fi Version Time is now: 8th December 2025 - 05:19 AM
