> Dash Pad Recovering
puffinator
post Dec 8 2014, 11:44 AM
Has anyone used "Just Dashes" to recover a dash pad? If so, can you provide an opinion. Quality of work and match of material to stock.
Has anyone used anyone else?
veekry9
post Dec 8 2014, 08:45 PM
OldMember
Group: Retired Members
Sure,the production tooling of the method Porsche used back then was state of the art.
The puffiness you refer to is the perception of the part's radii.
The tool used was chemically etched with acid to remove material from the mold surface.
Likely a silkscreen technique rather than a photographic method.
Anyone with automotive trim experience would know that.
It is a very nice result and the ashtray delete option is convenient.
Again,labour intensive.
Mikey914
post Dec 9 2014, 12:00 PM
The rubber man
QUOTE(veekry9 @ Dec 8 2014, 06:45 PM) *
These are 2 different techniques. Porsche made the dashes by forming the vinyl into the mold, then inserting a substructure into the top of the mold, closing it and injecting high density foam into the cavity.
Ask me how I know (IMG:style_emoticons/default/biggrin.gif)
Just Dashes take the core, grinds down the vinyl, applies a thermally activated glue and forms the vinyl over a thin pad to take up imperfections. Yes, it will have some give unlike the OEM, and as you stretch the vinyl the pattern will elongate. But short of a large custom tool it's a good down and dirty way to reuse the core, you just have to play with the sag in the inst cluster to to make it not sag. Very labor intensive, inexpensive to set up (relatively so).
puffinator   Dash Pad Recovering   Dec 8 2014, 11:44 AM
ClayPerrine   Has anyone used "Just Dashes" to recove...   Dec 8 2014, 12:09 PM
veekry9   Unpopular? Why?   Dec 8 2014, 01:19 PM
McMark   Weird. I talked with at least three different peo...   Dec 8 2014, 01:57 PM
SirAndy   AA is probably sending them to Just Dashs and rese...   Dec 8 2014, 02:10 PM
lonewolfe   Weird. I talked with at least three different pe...   Dec 8 2014, 03:34 PM
Tom_T   I've seen Just Dashes' work on other class...   Dec 8 2014, 02:05 PM
puffinator   I've seen Just Dashes' work on other clas...   Dec 8 2014, 03:07 PM
mepstein   Just dashes uses padding under the vinyl so it doe...   Dec 8 2014, 03:11 PM
dknechtly   How much?   Dec 8 2014, 03:24 PM
sbsix   Check this thread for Just Dashes. http://www.914...   Dec 8 2014, 03:40 PM
McMark   Somebody said $600-700 for a 914 dash.   Dec 8 2014, 04:07 PM
sbsix   I paid much less than that for my dash, but it...   Dec 8 2014, 05:43 PM
Highland   I think I paid just under $1100 for lower and...   Dec 8 2014, 05:48 PM
dlkawashima   The grain is not exact, so I'm glad I did bot...   Dec 8 2014, 08:02 PM
sbsix   That's why I did everything at once so that it...   Dec 8 2014, 06:16 PM
veekry9   Sure,the production tooling of the method Porsch...   Dec 8 2014, 08:45 PM
mepstein   Sure,the production tooling of the method Porsc...   Dec 8 2014, 09:01 PM
MoveQik   Sure,the production tooling of the method Porsche...   Dec 9 2014, 11:11 AM
Mikey914   Sure,the production tooling of the method Porsc...   Dec 9 2014, 12:00 PM
veekry9   How could you? It's technical.   Dec 8 2014, 09:09 PM
GregAmy   How could you? It's technical. Wow. Nice res...   Dec 9 2014, 10:28 AM
McMark   [quote name='veekry9' post='2120083' date='Dec 8 ...   Dec 9 2014, 11:00 AM
GregAmy   :rotfl: You obviously don't understand. Vee...   Dec 9 2014, 02:06 PM
altitude411   :agree: technical? :WTF: :rotfl: :lol4:   Dec 9 2014, 10:42 AM
veekry9   Moldmaking,tool+die+die-cast,light to heavy for de...   Dec 9 2014, 11:30 AM
veekry9   Exactomundo. :D The problem evident is the lack o...   Dec 9 2014, 01:15 PM
- Lo-Fi Version Time is now: 4th March 2026 - 01:26 PM
