> Aftermarket CV bolt's too soft???, "issues" with non-factory bolts?????
Mueller
post Aug 25 2004, 03:24 PM
914 Freak!
has anyone else found that the greenish CV bolts are soft???
I've had a few break while I was installing them and they snapped well under 20 lb's of torque (I tighten them using a torque wrench, I start off with a lower setting and work my way up to the proper setting)
I've never had a problem with the darker black colored CV bolts which I am guessing are factory spec and not just the generic VW bug replacment units?????
(picture "borrowed" from another thread (IMG:style_emoticons/default/smile.gif) )
Brad Roberts
post Aug 29 2004, 02:50 PM
914 Freak!
FYI:
I have installed upwards of 30-40 of these "green" bolts with NO issues to date. I'm betting Mikes Torque wrench is screwed up OR the threads in the flange where jacked up.
nother FYI:
The pic shown with the longer bolt... one of those is not stock. My green bolts are the exact same length.
I have been VERY careful lately torquing the CV bolts because of all the recent failures. If I feel one is going past the point of no return I stop and pic another one to torque down. I also dont feel it is neccassary to torque them more than once. Get them "short ratchet" tight and come back with the torque wrench.
B
Mueller   Aftermarket CV bolt's too soft???   Aug 25 2004, 03:24 PM
synthesisdv   Got these from EBS, (engine builders supply) Says...   Aug 25 2004, 03:35 PM
echocanyons   I got a pair from EBS that had the greenish look t...   Aug 25 2004, 03:53 PM
736conver   Other differences I have notice. The greenish/si...   Aug 25 2004, 04:01 PM
synthesisdv   Isn't most of the torque load carried by the s...   Aug 25 2004, 04:12 PM
Headrage   Where can you get the black hardened ones?   Aug 25 2004, 04:14 PM
TimT
  Aug 25 2004, 04:25 PM
Headrage   What do I tell them? Will they know if I just say...   Aug 25 2004, 04:28 PM
Mueller
  Aug 25 2004, 04:35 PM
GWN7   Isn't there a grade rating on them? Should be ...   Aug 25 2004, 04:49 PM
synthesisdv   Its an M8 x 45... dr   Aug 25 2004, 04:49 PM
synthesisdv     Aug 25 2004, 04:52 PM
736conver   The black bolts I have are 12.9. The silver ones ...   Aug 25 2004, 04:59 PM
TimT   Didnt someone recently post about flywheel bolts t...   Aug 25 2004, 05:26 PM
TimT   Im a bolt geek LOL the on on the left has nice r...   Aug 25 2004, 05:27 PM
TimT   The bolt on the right looks like a cheesy knock of...   Aug 25 2004, 05:30 PM
Verruckt   <...   Aug 25 2004, 05:35 PM
Mark Henry     Aug 26 2004, 06:51 AM
thomasotten   Wait a minute... I bought some CV boot repair kit...   Aug 26 2004, 07:49 AM
DonTraver   When I want to be sure that the bolts, hardware ar...   Aug 26 2004, 08:44 AM
Brad Roberts   FYI: I have installed upwards of 30-40 of these "...   Aug 29 2004, 02:50 PM
- Lo-Fi Version Time is now: 18th March 2026 - 05:58 AM
