| lagunero |
Sep 20 2004, 05:38 PM
Donkey Member ![]() ![]() ![]() Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
I need to make a decision soon. Assuming I can afford it, what system would you recommend for someone who doesn't want (nor is capable) to fiddle with fuel management systems? I have a 2.0 long block that I'll be getting to soon. I don't mind changing the internals. My goal is to have a reliable set up. I do not have a harness or injection system other then the one on my 1.7. I've looked at the websites for Megasquirt and KitCarlson but both seem to be for the serious DIY''er. I didn't mind carbs before but I just don't have the time to waste on them anymore.
HP or economy are not the issue, reliability is. Thanks and.....HELP! |
| Mark Henry |
Sep 20 2004, 08:00 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I have the SDS system. The install was straight forward except for the crank trigger (you don't "have" to have crankfire) set-up.
Cam choice is important with PEFI, although my SDS hates the crappy Scat C-25 I have now I got it running real good, least better than carbs. I'm going to hit Jake up for a cam when I do my new engine this winter. As far as programing goes...that was the easy part with my SDS. you can see my install at: http://www.914world.com/bbs2/index.php?act...t=ST&f=2&t=5396 and the update at: http://www.914world.com/bbs2/index.php?act...t=0#entry204559 |
lagunero What FI system should I install? Sep 20 2004, 05:38 PM
lapuwali Actually, the Kit Carlson system is likely to be y... Sep 20 2004, 05:53 PM
TimT I have webers on my /6 simple and reliable...what... Sep 20 2004, 06:03 PM
lagunero Thanks guys. That's pretty much the conclusion... Sep 20 2004, 07:39 PM
lagunero Thanks for the info. It seems that you have worked... Sep 20 2004, 09:25 PM
mike_the_man From everything I've heard, the Kit Carlson sy... Sep 20 2004, 09:35 PM
Jake Raby No serious DIY on the Kit Carlson system..
The wa... Sep 20 2004, 09:37 PM
tommy914 ![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 11:34 AM |
