> What FI system should I install?, like the diet, I'd like to avoid carbs
lagunero
post Sep 20 2004, 05:38 PM
Donkey Member
I need to make a decision soon. Assuming I can afford it, what system would you recommend for someone who doesn't want (nor is capable) to fiddle with fuel management systems? I have a 2.0 long block that I'll be getting to soon. I don't mind changing the internals. My goal is to have a reliable set up. I do not have a harness or injection system other then the one on my 1.7. I've looked at the websites for Megasquirt and KitCarlson but both seem to be for the serious DIY''er. I didn't mind carbs before but I just don't have the time to waste on them anymore.
HP or economy are not the issue, reliability is.
Thanks and.....HELP!
Jake Raby
post Sep 20 2004, 09:37 PM
Engine Surgeon
No serious DIY on the Kit Carlson system..
The way we'll be selling it all you do is hook up the harnass, you can even use stock injectors and etc..
I can attest to how easy it was, even a test system with a test harnass and brain. We installed it in one day on my 912 and did so from carbs.
Still no issues and 4,000 miles on the system so far
lagunero   What FI system should I install?   Sep 20 2004, 05:38 PM
lapuwali   Actually, the Kit Carlson system is likely to be y...   Sep 20 2004, 05:53 PM
TimT   I have webers on my /6 simple and reliable...what...   Sep 20 2004, 06:03 PM
lagunero   Thanks guys. That's pretty much the conclusion...   Sep 20 2004, 07:39 PM
Mark Henry   I have the SDS system. The install was straight fo...   Sep 20 2004, 08:00 PM
lagunero   Thanks for the info. It seems that you have worked...   Sep 20 2004, 09:25 PM
mike_the_man   From everything I've heard, the Kit Carlson sy...   Sep 20 2004, 09:35 PM
Jake Raby   No serious DIY on the Kit Carlson system.. The wa...   Sep 20 2004, 09:37 PM
tommy914
- Lo-Fi Version Time is now: 1st May 2026 - 11:33 AM
