> Cell phone / Smartphone mount for Porsche 914, NLA - New design coming
johannes
post Oct 25 2015, 04:46 AM
Club Porsche 914 France member since 2005
Region Association: France
THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE
https://www.youtube.com/watch?v=yDaeY1dAp0M
I just finished and tested the first prototype of the 3D printed cell phone / smartphone mount. The mount replaces the ashtray.
This is available as a kit. You will have to order the 3D parts directly from the printer. The 3D printing is made with Polyamide. Its a white, very fine, granular powder. The result is a strong, somewhat flexible material that can take impacts and resist pressure while being bent. The surface has a sandy, granular look, and is slightly porous. The material can be painted.
To complete the kit you will also have to source or order
4x M4x12 screws and nuts
1x M4x15 screw
2x 5x70mm rubberbands
2x small pieces of 10x3mm rubber windows seal
(see ordering post below)
- Fits most phones from the small I-Phone to the large Galaxy from 6 to 8 cm wide (2.3/8 to 3.1/4)
post Nov 23 2015, 10:33 PM
OK, what am I missing? The grip range is too large for my Iphone which is ~58mm. Do I need my phone in some case to fit? 2nd, it's floppy and I dont want to over tighten that little bolt. Not sure wh it has mch threads eith. Seems like the long one would be a tapered screw like a sheet rock screw. (IMG:style_emoticons/default/confused24.gif) Is it just me???????
johannes
post Nov 24 2015, 03:17 AM
QUOTE(76-914 @ Nov 23 2015, 08:33 PM) *
The phone support was designed for minimum 60mm so you are a bit under. One of the clamps is free and the other has to be ajusted and tightened.
You can put your phone in a case, this would be the easiest way to fix the issue.
The clamps have a rake and if your phone is very thin, you can glue a 3 to 5mm rubber or foam on the surface that will receive the back of your phone. THis will push the phone towards the clamps.
You can shorten the main part about 1mm each side with a file and gain 2mm clamp travel
If the ball join with main frame assembly is floppy you better disassemble and put some glue on the surface before re assembling. This is not intended to be disassembled in the future.
post Nov 24 2015, 10:56 AM
QUOTE(johannes @ Nov 24 2015, 01:17 AM) *
Pretty much what I planned on doing. I'll use a strip of foam pipe insulation to correct the dimensional problem. Then I'll replace the machine screw w/ another style and JB Weld the square post to the body. I'll post my results if I have results. (IMG:style_emoticons/default/dry.gif)
johannes   Cell phone / Smartphone mount for Porsche 914   Oct 25 2015, 04:46 AM
johannes   THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAI...   Oct 25 2015, 04:46 AM
GregAmy   Finally got around to assembling mine today (we hi...   Mar 8 2016, 03:39 PM
johannes   Finally got around to assembling mine today (we h...   Mar 8 2016, 04:04 PM
johannes   ASSEMBLY INSTRUCTIONS 1- With a small plier, cut ...   Oct 25 2015, 04:46 AM
23e Heure   Hi Johannes, I'm putting my kit together. Que...   Jan 28 2018, 06:09 AM
johannes   Hi Johannes, I'm putting my kit together. Qu...   Jan 29 2018, 03:58 AM
Harpo   Very interested. Thanks for doing this David   Oct 25 2015, 05:59 AM
cary   Very interested. Thanks for doing this David ...   Oct 25 2015, 06:53 AM
Steve   Interested also   Oct 25 2015, 08:16 AM
Bossman   December seems so far away!   Oct 25 2015, 09:20 PM
johannes   December seems so far away! I may sell a fe...   Oct 26 2015, 03:43 AM
Steve   Just in time for Christmas!! Now everyone...   Oct 25 2015, 10:58 PM
johannes   Some more news I made some refinements on the des...   Oct 26 2015, 04:02 AM
sb914   I'm in for one with hardware ,thanks   Oct 26 2015, 09:47 AM
76-914   +1 here, as well.   Oct 26 2015, 09:59 AM
MrHyde   I'm in for one with the hardware if you can sh...   Oct 26 2015, 10:46 AM
johannes   I'm in for one with the hardware if you can s...   Oct 26 2015, 10:56 AM
wes   I like it and want one as a kit! thanks   Oct 26 2015, 12:36 PM
zipedadoo   One for me please....:)   Oct 26 2015, 01:40 PM
Chris Pincetich   :woohoo: :beer2:   Oct 26 2015, 08:36 PM
db9146   Looks good to me!!   Oct 26 2015, 09:14 PM
914-300Hemi   Count me in for one. Looks pretty cool.   Oct 26 2015, 09:27 PM
Eric_Shea   Consider cord storage for a charger application. ...   Oct 27 2015, 08:08 AM
ben*james   Consider cord storage for a charger application. ...   Oct 27 2015, 08:23 AM
johannes   Consider cord storage for a charger application. ...   Oct 27 2015, 03:31 PM
PThompson509   Also very interested!   Oct 27 2015, 09:21 AM
dflesburg   if you can do that, it shouldn't take you any ...   Oct 27 2015, 11:41 AM
clapeza   Instead of having to source it out to a local thir...   Oct 27 2015, 12:12 PM
johannes   Instead of having to source it out to a local thi...   Oct 27 2015, 03:47 PM
GregAmy   Subscribing...CLEVER! Excellent mount for the ...   Oct 28 2015, 12:57 PM
1972 914 2.0   This is a good thing you're doing. I've ju...   Oct 29 2015, 07:26 PM
johannes   I just ordered the 3D print with the cord storage....   Oct 30 2015, 03:19 AM
johannes   ... [b]The kit is now available. Read post 2 on ...   Nov 10 2015, 10:55 AM
Kansas 914   Order placed!   Nov 10 2015, 11:39 AM
Steve   Order placed!! Thanks!!   Nov 10 2015, 04:35 PM
Harpo   Ordered mine. Thanks   Nov 11 2015, 08:58 AM
76-914   The order form would not recognize the USA phone f...   Nov 11 2015, 09:32 AM
johannes   The order form would not recognize the USA phone ...   Nov 11 2015, 09:36 AM
malcolm2   very cool.   Nov 11 2015, 10:10 AM
76-914   Done. Thx for doing this, Johannes. Our phones hav...   Nov 11 2015, 10:14 AM
rgolia   Just ordered mine....thank you much for this... :b...   Nov 11 2015, 02:48 PM
KELTY360   Ordered 1 + kit with black screws. Great looking i...   Nov 11 2015, 06:09 PM
johannes   Started to ship the ancillary parts ... Still miss...   Nov 13 2015, 11:17 AM
Kansas 914   WOW! Fast shipping to the US. I just received ...   Nov 20 2015, 05:48 PM
Steve   I also got mine today. Just waiting for the screw...   Nov 20 2015, 06:50 PM
johannes   I also got mine today. Just waiting for the scre...   Nov 22 2015, 03:39 PM
76-914   Hah! I received the screw kit but not the hold...   Nov 21 2015, 09:09 AM
JoeD   Super cool! I ordered the kit and it's sup...   Nov 21 2015, 10:22 AM
karmann   Will these be available in black in the near futur...   Nov 21 2015, 01:42 PM
johannes   Will these be available in black in the near futu...   Nov 22 2015, 01:28 PM
johannes   Information about ancillaries. There next to no de...   Nov 22 2015, 01:30 PM
76-914   OK, what am I missing? The grip range is too large...   Nov 23 2015, 10:33 PM
johannes   OK, what am I missing? The grip range is too larg...   Nov 24 2015, 03:17 AM
76-914   OK, what am I missing? The grip range is too lar...   Nov 24 2015, 10:56 AM
JoeD   Johannes, I received my kit from iMaterialize yest...   Nov 24 2015, 07:33 AM
johannes   Thank you for your message JoeD. Yes it was very c...   Nov 24 2015, 07:49 AM
76-914   Made those two mods and luv it :wub: Also hit it ...   Nov 25 2015, 05:27 PM
johannes   Looking good. For small phone I suggest you put tw...   Nov 25 2015, 05:38 PM
cary   Screw kit arrived yesterday. Hopefully the mount w...   Nov 26 2015, 10:24 AM
johannes   Screw kit arrived yesterday. Hopefully the mount ...   Nov 26 2015, 10:37 AM
johannes   Just got a mail from IMaterialise the company tha...   Nov 27 2015, 02:07 AM
Harpo   Good evening guys, I ordered one but received thr...   Nov 27 2015, 05:59 PM
johannes   Good evening guys, I ordered one but received th...   Nov 28 2015, 09:26 AM
76-914   Good evening guys, I ordered one but received t...   Nov 28 2015, 09:53 AM
cary   Hmmm............ David, I was at work and didn...   Nov 27 2015, 07:57 PM
Steve   Great product. I used a dremel tool with cutoff w...   Nov 28 2015, 09:35 AM
johannes   Great product. I used a dremel tool with cutoff ...   Nov 28 2015, 09:52 AM
Steve   Great product. I used a dremel tool with cutoff ...   Nov 28 2015, 10:12 AM
Harpo   I just mailed Cary's cell phone holder. It sh...   Nov 30 2015, 09:46 AM
cary   Finally put mine together. The precision is amazin...   Jan 9 2016, 07:27 PM
johannes   Finally put mine together. The precision is amazi...   Jan 10 2016, 06:19 AM
cary   Cool Sliding portion will need to be cut with a...   Jan 22 2016, 10:05 PM
johannes   That is glossy ! ;)   Jan 23 2016, 01:46 AM
cary   Home Depot only had flat and gloss. :( Stopped a...   Jan 23 2016, 10:38 PM
kellygeorge   Just placed my orders for the mount and Ancillary ...   Feb 18 2016, 07:07 PM
johannes   Just placed my orders for the mount and Ancillary...   Feb 18 2016, 07:20 PM
kellygeorge   Received all my parts and assembled today. It...   Feb 29 2016, 09:53 PM
76-914   A pleasant addition and worth the $$.   Feb 19 2016, 09:33 AM
iwanta914-6   This is amazing. If i had a 914 I would be buying...   Feb 19 2016, 09:53 AM
johannes   Looks interesting. I will give it a try   Mar 1 2016, 05:45 AM
cary   Here's a shot of my mount is use on the way to...   May 23 2016, 08:38 PM
johannes   Are you using Google Maps ?   May 23 2016, 11:41 PM
cary   Yep .............   May 23 2016, 11:47 PM
matthepcat   Oops. My question was asked earlier.... Free bump.   May 24 2016, 09:24 AM
cary   New modification ......................   Jun 24 2016, 09:27 PM
BillC   I ordered one of these mounts last year, but never...   Apr 23 2017, 08:41 AM
johannes   I ordered one of these mounts last year, but neve...   Apr 23 2017, 09:08 AM
mepstein   I just purchased a kit and hardware. :)   Apr 23 2017, 11:19 AM
johannes   THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN COMMING   Mar 12 2018, 03:20 AM
drem914   THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN COMMIN...   Feb 22 2020, 04:56 PM
johannes   Prototype done. Works fine. Looks great. Productio...   Feb 23 2020, 04:51 AM
barefoot   My I phone 6 sits nicely in the ash tray when held...   Feb 23 2020, 08:11 AM
drem914   My I phone 6 sits nicely in the ash tray when hel...   Feb 23 2020, 09:33 AM
76-914   My I phone 6 sits nicely in the ash tray when hel...   Feb 23 2020, 09:52 AM
GregAmy   I have one of the older design that someone can ha...   Feb 23 2020, 04:47 PM
914bub   I have one of the older design that someone can h...   Apr 12 2020, 10:42 PM
tyfighter123   Any more news on these?   Apr 12 2020, 09:47 PM
forrestkhaag   THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN...   Oct 23 2020, 03:35 PM
dangrouche   here's an alternative solution I've employ...   Oct 23 2020, 07:25 PM
- Lo-Fi Version Time is now: 15th June 2026 - 04:31 AM
