| SixerJ |
May 4 2016, 08:33 AM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Continued stripping my -6 at the weekend and took the blower and wiper motor assembly out. Discovered on removal that she had a -4 wiper assembly installed when the car was converted to racer back in the 2000's
Does anyone have pictures of a complete and correct 914-6 wiper and motor assembly and how does it differ from say an early >73 911 set up, different spindle spacing, wiring, motor? Also does anyone have any pictures of a naked genuine 914-6 steering column tube (914.347.072.00). I've looked through many of the build threads, parts vault and column conversions (Clay's and SirA's below) http://www.914world.com/bbs2/index.php?sho...=100179&hl= http://www.914world.com/bbs2/index.php?showtopic=82045 Picture wise I have only found genuine -6 column tubes assembled up with switches / clam shells or say Clays naked converted tube below Bolt hole spacing on the flat plate of a genuine 6's tube and later 4 plate looks wider, what about the early 4 column plates, do they match the 6 column? I knew that I would have to get all the column parts together for my car when I purchased it & sourced a complete 911 column not long after I bought her just in case I have to go down the tube conversion route / if I cannot source a genuine six tube I didn't realise that I would also have to find the -6 wiper motor assembly as well.....any pictures, answers and guidance / leads on -6 wiper assembly and column tube would be appreciated Thanks Jon Attached image(s)
| 914Sixer |
May 4 2016, 11:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,466 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
The wiper rack is a cut down version of the 69-73 911 rack. It has a support bar for the wiper motor. You can take a 911 one and make it into the -6 rack.
The -6 column is the 69-73 911 column with the 914 mounting pad welded on to it. Easy to fabricate with the right parts. -6 column covers do NOT have a u shaped cut in them. They are solid on both sides. Attached image(s)
SixerJ 914-6 Steering Column Tube and Wiper Assembly May 4 2016, 08:33 AM
rgalla9146 914 6 steering column mount compared to later (... May 4 2016, 12:27 PM
rgalla9146 914 6 3 speed wiper rack May 4 2016, 12:36 PM
SixerJ Thanks guys, that was exactly what I was after
91... May 4 2016, 02:27 PM
914Sixer 2 Pictures of a real -6 wiper. 3rd picture is ear... May 4 2016, 03:10 PM
rgalla9146 Well, this is interesting.
I just looked at the ... May 4 2016, 05:50 PM
914Sixer Rory,
Yours appears to be from a -4. -6 wiper mot... May 4 2016, 06:18 PM
rgalla9146
Rory,
Yours appears to be from a -4. -6 wiper mo... May 4 2016, 07:37 PM
914Sixer Added another picture of -6 wiper rack with only 3... May 4 2016, 08:21 PM
toolguy My Six Wiper assembly and motor May 4 2016, 08:32 PM
ClayPerrine Thought that picture looked familiar.... :)
M... May 4 2016, 09:20 PM
Harpo It appears that the 914-4 plate is flush with the ... Dec 4 2016, 11:53 AM
SixerJ
It appears that the 914-4 plate is flush with the... Dec 4 2016, 12:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 08:04 PM |
