> 914-6 Steering Column Tube and Wiper Assembly, Advice and identification photos please
SixerJ
post May 4 2016, 08:33 AM
Region Association: England
Continued stripping my -6 at the weekend and took the blower and wiper motor assembly out. Discovered on removal that she had a -4 wiper assembly installed when the car was converted to racer back in the 2000's
Does anyone have pictures of a complete and correct 914-6 wiper and motor assembly and how does it differ from say an early >73 911 set up, different spindle spacing, wiring, motor?
Also does anyone have any pictures of a naked genuine 914-6 steering column tube (914.347.072.00). I've looked through many of the build threads, parts vault and column conversions (Clay's and SirA's below)
http://www.914world.com/bbs2/index.php?sho...=100179&hl=
http://www.914world.com/bbs2/index.php?showtopic=82045
Picture wise I have only found genuine -6 column tubes assembled up with switches / clam shells or say Clays naked converted tube below
Bolt hole spacing on the flat plate of a genuine 6's tube and later 4 plate looks wider, what about the early 4 column plates, do they match the 6 column?
I knew that I would have to get all the column parts together for my car when I purchased it & sourced a complete 911 column not long after I bought her just in case I have to go down the tube conversion route / if I cannot source a genuine six tube
I didn't realise that I would also have to find the -6 wiper motor assembly as well.....any pictures, answers and guidance / leads on -6 wiper assembly and column tube would be appreciated
Thanks
Jon
rgalla9146
post May 4 2016, 12:27 PM
914 6 steering column mount compared to later ('75 - '76 ? ) mount, 6 column on right.
Second pic compares 6 column mount to early 4 cyl. column. It appears a 6 column will bolt directly into an early 4 cyl. chassis (up to '75 ?)
The bolt spacing is the same.
The '73-'74 column has a suitable plate to weld onto a 911 column to create a "do it yourself "
- Lo-Fi Version Time is now: 15th April 2026 - 08:03 PM
