| SixerJ |
May 4 2016, 08:33 AM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Continued stripping my -6 at the weekend and took the blower and wiper motor assembly out. Discovered on removal that she had a -4 wiper assembly installed when the car was converted to racer back in the 2000's
Does anyone have pictures of a complete and correct 914-6 wiper and motor assembly and how does it differ from say an early >73 911 set up, different spindle spacing, wiring, motor? Also does anyone have any pictures of a naked genuine 914-6 steering column tube (914.347.072.00). I've looked through many of the build threads, parts vault and column conversions (Clay's and SirA's below) http://www.914world.com/bbs2/index.php?sho...=100179&hl= http://www.914world.com/bbs2/index.php?showtopic=82045 Picture wise I have only found genuine -6 column tubes assembled up with switches / clam shells or say Clays naked converted tube below Bolt hole spacing on the flat plate of a genuine 6's tube and later 4 plate looks wider, what about the early 4 column plates, do they match the 6 column? I knew that I would have to get all the column parts together for my car when I purchased it & sourced a complete 911 column not long after I bought her just in case I have to go down the tube conversion route / if I cannot source a genuine six tube I didn't realise that I would also have to find the -6 wiper motor assembly as well.....any pictures, answers and guidance / leads on -6 wiper assembly and column tube would be appreciated Thanks Jon Attached image(s)
| rgalla9146 |
May 4 2016, 05:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Well, this is interesting.
I just looked at the wiper mech in my long owned 914 6 It has the support bracket as seen on Marks 6 unit and a bracket welded to the motor to which it attaches. Yes, the motor is black, stamped steel rear cover (silver) with extra bracket attached. All original parts. The one that I've had on the shelf for twenty years (pictured) does not. I put a note on it way back then, when I removed it from another 6 Could there be two versions ? I have another car but can't get to look at it too soon. Mark, is my pictured one from a 4 ? Do the elec. connections tell ? |
SixerJ 914-6 Steering Column Tube and Wiper Assembly May 4 2016, 08:33 AM
914Sixer The wiper rack is a cut down version of the 69-73 ... May 4 2016, 11:20 AM
rgalla9146 914 6 steering column mount compared to later (... May 4 2016, 12:27 PM
rgalla9146 914 6 3 speed wiper rack May 4 2016, 12:36 PM
SixerJ Thanks guys, that was exactly what I was after
91... May 4 2016, 02:27 PM
914Sixer 2 Pictures of a real -6 wiper. 3rd picture is ear... May 4 2016, 03:10 PM
914Sixer Rory,
Yours appears to be from a -4. -6 wiper mot... May 4 2016, 06:18 PM
rgalla9146
Rory,
Yours appears to be from a -4. -6 wiper mo... May 4 2016, 07:37 PM
914Sixer Added another picture of -6 wiper rack with only 3... May 4 2016, 08:21 PM
toolguy My Six Wiper assembly and motor May 4 2016, 08:32 PM
ClayPerrine Thought that picture looked familiar.... :)
M... May 4 2016, 09:20 PM
Harpo It appears that the 914-4 plate is flush with the ... Dec 4 2016, 11:53 AM
SixerJ
It appears that the 914-4 plate is flush with the... Dec 4 2016, 12:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 08:05 PM |
