| Engman |
Oct 7 2004, 12:44 PM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Well - here is my list of stuff to finish before the FFC04.
Reinstall side marker lights Set idle speed (running 1300rpm at idle) Fix front dash cover Install new door seals Check CV bolts Check Tranny Fluid Decide what parts to take for swap meet Install 914 Club sticker (duh) What has everyone else got left? I know Sean is still working on brakes and sway bars (IMG:style_emoticons/default/laugh.gif) M |
| seanery |
Oct 7 2004, 01:24 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
ok, here we go....
1. figure out why dustcaps won't fit front rotors 2. hope that replacement hardware shows up so I can install front calipers 3. install front calipers 4. finish building new hard lines (oops-gotta do this before #3) 5. replace pads in rear calipers & set tolerances (hope they clear the 914-6 rotors back there) 6. install hard lines in rear 7. install rear calipers 8. figure out how to get the damn rear sway bar attached to the balls on the shock mounts 9. fit new valence to front of car 10. uh, now it's scary - check inside of case to see if there is any debris 11. if no debris - replace pistons & cylinders with 96s that are in garage 12. get heads back - damn, why so long? 12. install heads & rest of motor stuff 13. put tin on 14. install motor 15. hope tailshifter isn't trashed 16. install tranny (well-with #14) 17. hope all that goes well and the car works 18. finish Engman fuse panel install 19. add J West Fog flash module 20. paint turn signal block off plates 21. install turn signal block off plates 22. install pedal board 23. install new pedals 24. wash the damn car 25. hope it works well |
Engman Getting ready for the FFC Oct 7 2004, 12:44 PM
itsa914 Put the Fuchs back on and wash the car :D Oct 7 2004, 12:54 PM
ArtechnikA change oil & filter
change air filter
replace spar... Oct 7 2004, 12:54 PM
jim912928 I've got a list!
1. all 4 wheels brake re... Oct 7 2004, 01:14 PM
seanery 26. install fuel tank :headbang: Oct 7 2004, 01:26 PM
Engman Wow Sean. Do we need to add Thursday prior to the ... Oct 7 2004, 01:31 PM
Jeroen
rick 918-S Oh Ya, I've got a list! Oct 7 2004, 01:58 PM
jim912928 man...after seeing all this for once I do feel lik... Oct 7 2004, 02:10 PM
dakotaewing After you guys get everything else dealt with, mak... Oct 7 2004, 04:00 PM
ArtechnikA the packing list is a separate list, and yes, the ... Oct 7 2004, 04:08 PM
Engman :idea: Kinda sounds like the Alien may make a land... Oct 7 2004, 07:01 PM
rick 918-S I've been asked to help out with claims in Flo... Oct 7 2004, 07:18 PM
jim912928 Progress on my list of to do's:
1. pedal clus... Oct 8 2004, 05:35 PM
cnavarro 1. Pulled engine and tranny out of the 912 with th... Oct 8 2004, 05:46 PM
qa1142 1) change oil
2) once through - Quick once over
3)... Oct 8 2004, 05:57 PM
GTeener Only one thing on my list:
Mail out 914 GURL hats... Oct 8 2004, 05:59 PM
jim912928 Anybody want to start a caravan from those of us u... Oct 8 2004, 06:18 PM
itsa914 Funny you mention that Jim, Julie & I were just ta... Oct 8 2004, 06:30 PM
jim912928 31 or 65 doesn't matter. Only takes me about ... Oct 8 2004, 06:43 PM
itsa914 I'm working on it, if anything, I can give ya ... Oct 8 2004, 06:56 PM
seanery are you guys coming down Friday? missing the get d... Oct 8 2004, 09:33 PM
itsa914 Julie & I will be down Friday late afternoon / eve... Oct 8 2004, 09:36 PM
ArtechnikA Friday's our travel day, our plan is to arrive... Oct 8 2004, 10:02 PM
Doug Leggins For the 72
-Fix a loose connection on the left rea... Oct 8 2004, 10:53 PM
seanery Rich,
I believe this is the week before the time ... Oct 9 2004, 07:59 AM
jim912928 Ok...it's mid-day saturday (missing the ND gam... Oct 9 2004, 01:20 PM
SpecialK HIGHLY doubtful that my '74 will be making the... Oct 9 2004, 02:54 PM
tommy914 1. fix oil pump leak.... how hard will this be wit... Oct 9 2004, 03:48 PM
tommy914 8 days to go.
Oil pump re-sealed.... just have to ... Oct 12 2004, 11:58 AM
jim912928 Took mine out for a test drive today. Clutch is s... Oct 12 2004, 12:02 PM
mudfoot76 It looks like my new engine and gearbox are all so... Oct 12 2004, 12:51 PM
GTeener
ArtechnikA <... Oct 12 2004, 03:14 PM
GTeener <... Oct 13 2004, 01:30 PM
jim912928 Ok..here is where I'm at:
1. ordered new blee... Oct 14 2004, 11:43 AM
jim912928 FFC work to be done to make it update!:
1. I ... Oct 15 2004, 06:54 PM
tommy914 Loading up! Oct 20 2004, 06:32 PM
seanery woohooo!
drive safely :driving: Oct 20 2004, 06:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:56 AM |
