| Beakster |
Aug 3 2016, 08:04 PM
Member ![]() ![]() Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Is it possible to put a older 6 cyl Boxster engine and tranny in a 914 and has anyone done it ..
| ClayPerrine |
Aug 5 2016, 01:38 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
My question is "Why would you want to?"
The Boxster engine is notorious for bottom end failures, and they are getting a premium for good ones because a lot of Boxster owners are looking for a replacement. There is even a company offering a kit to put a Subaru 6 into the Boxster chassis because of the failures. Frankly, its not worth the effort. Heavier than a 911 six, less HP, and it requires a radiator that adds even more weight. |
| Vapor_locked |
Aug 5 2016, 02:08 PM
Member ![]() ![]() Group: Members Posts: 74 Joined: 1-August 12 From: the middle of the time before Member No.: 14,746 Region Association: Upper MidWest |
My question is "Why would you want to?" The Boxster engine is notorious for bottom end failures, and they are getting a premium for good ones because a lot of Boxster owners are looking for a replacement. There is even a company offering a kit to put a Subaru 6 into the Boxster chassis because of the failures. Frankly, its not worth the effort. Heavier than a 911 six, less HP, and it requires a radiator that adds even more weight. There are differing degrees of mental illness, coupled with wallet thickness that make people do what they do, there really is no other reasonable explanation. It will only drive you crazy to try to figure out someone who is crazy! (IMG:style_emoticons/default/wink.gif) |
Beakster Boxster Engine in a 914 Aug 3 2016, 08:04 PM
SirAndy If i recall correctly, the Boxster engine is too w... Aug 3 2016, 08:09 PM
Beakster
If i recall correctly, the Boxster engine is too ... Aug 3 2016, 08:23 PM
Jeff Bowlsby "You cannot put a Boxster drivetrain in a 914... Aug 3 2016, 08:58 PM
ajracer Previously completed a Chev V8 conversion and used... Aug 3 2016, 08:58 PM
Optimusglen Boxster trans is not a big issue, the actual engin... Aug 3 2016, 09:00 PM
barrym I seem to recall someone was working on it and it ... Aug 3 2016, 09:38 PM
BIGKAT_83 Here are pictures of a running car in Aussie. Go t... Aug 5 2016, 07:22 AM
mepstein Why would you want a Boxter engine? Aug 5 2016, 07:56 AM
Chris H. Very interesting. The intake is flipped and the t... Aug 5 2016, 09:08 AM
RobW That's a lot of engine in there..... Aug 5 2016, 10:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:48 AM |
