| Optimusglen |
Aug 9 2016, 06:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 940 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
New rings and a light hone are going in my project, started looking around at my go-to for type 4's and it looks like AA doesnt carry this set. Any recommendations for another vendor?
| Optimusglen |
Aug 10 2016, 08:29 AM
What does KB stand for?
Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. |
| Mark Henry |
Aug 10 2016, 08:45 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
What does KB stand for? Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. That's why I put that up there, everyone who stated Hastings assumed you had KB's, Keith Black pistons. I knew you had either measured wrong or had a different piston. And yes a 4.75mm ring in a 5mm groove would be bad. Deves makes a 2 x 2 x 5mm set, you can get them through aircooled.net http://vwparts.aircooled.net/DEVES-Piston-...es-96-2-2-5.htm |
| TheCabinetmaker |
Aug 10 2016, 03:19 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,375 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What does KB stand for? Looks as if my pistons are NPR, and European Motor works sells a set of 2 x 2 x 5 marked as NPR. Couldn't find a set that matches that on Hastings website but I didn't call so maybe they can set me up. having never done rings, I assume that 4.75 in a 5mm groove is a no-no. That's why I put that up there, everyone who stated Hastings assumed you had KB's, Keith Black pistons. I knew you had either measured wrong or had a different piston. And yes a 4.75mm ring in a 5mm groove would be bad. Deves makes a 2 x 2 x 5mm set, you can get them through aircooled.net http://vwparts.aircooled.net/DEVES-Piston-...es-96-2-2-5.htm You are exactly right mark. Just assumed. Thanks |
Optimusglen piston ring set 96mm 2 x 2 x 5 Where to buy? Aug 9 2016, 06:25 PM
The Cabinetmaker You can buy directly from Hastings Aug 9 2016, 07:21 PM
Jetsetsurfshop Call Hasting. I just installed oil rings from them... Aug 9 2016, 09:20 PM
Steve Pratel European Motor works sells them too. Aug 9 2016, 09:47 PM
Optimusglen Found em, thanks all! Aug 10 2016, 07:49 AM
Mark Henry KB's are 2mm x 2mm x 4.75mm Aug 10 2016, 08:12 AM
maf914
Keith Black? :shades... Aug 10 2016, 08:35 AM
Optimusglen Most excellent, thank you! Aug 10 2016, 08:51 AM
porschetub
New rings and a light hone are going in my projec... Aug 10 2016, 02:11 PM
porschetub Good price for a quality ring set,but I seem to re... Aug 10 2016, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 11:02 AM |
