| Olympic 914 |
Sep 8 2016, 07:02 PM
![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
I have had these wheels for a while now but had not tried fitting them to the car before. they were buried in the front of the storage locker I rent to keep the rest of the cars parts. So today I moved everything and brought them home to try fitting them.
![]() I already had a good idea of the tire sizes I wanted to run. my original thought was to go with 245 / 50 /16 on the 8" Fuchs on the rear and 225/ 50 16 on the 7"s for the front. Good thing I didn't buy the tires........... Even though the fenders were flared with the intention of using these size wheels it seem that the space under the fenders is not as cavernous as I thought. After trying the 8s on the rear I am not even sure 225s will fit. ![]() ![]() With a straight edge on the outer lip of the wheels I have 3/16s on the pass side and only 1/16 on the driver side, that in addition to the 5/16s thickness of the outer lip on the wheel equals 8 3/4 total possible tire width. The specs on the 225 /50 tires are based on a 7" wheel and show a 8.1 in tread and a 9.2 sectional width. so the tread will fit under the fender but I don't know if the sidewall will rub. The GFs car has 225 45s on 7.5in rims and the sidewall is almost straight up from the wheel. Really want to use the 8" wheels but I would hate to ruin the new paint job. probably go with 205 / 50 s on the front 7" wheels The wheels do look nice. ![]() ![]() How much space do you need to fit the 225's under the fenders? I was looking at the BF Goodrich G-force Comp2 A/S they are available in the sizes I need. (would like) |
| mskala |
Sep 8 2016, 07:21 PM
R ![]() ![]() ![]() Group: Members Posts: 1,965 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I have 7.5"x16 3-piece rims that go on my pulled narrow body with Hoosier
205's which are probably as wide as your 225s. However, the wheels are built as ~38mm offset where the 8x15 you have are 11mm offset. Also, on my car I need an exact amount of spacers that is different each side. No joke, after the first run of first autocross with these tires, I needed to take off the left wheel and remove a 1/16" spacer to avoid burning paint. And it now barely rubs on the frame. So, unless you cut and sectioned your rear fenders to get at least 1" more room than I got by pulling, I think you will not be able to make them fit. (Also I have a lot of camber and stiff springs, which helps). ![]() |
Olympic 1.7 Tire fitment for 8" Fuchs Sep 8 2016, 07:02 PM
mepstein 225's on 8x15 or 16 Fuchs work really well wit... Sep 8 2016, 07:18 PM
Olympic 1.7 The Fuchs I have are 7x16 and 8x16 both with the 2... Sep 8 2016, 07:35 PM
MoveQik FWIW, as hard as the body shop tried, they could n... Sep 8 2016, 08:56 PM
Olympic 1.7
FWIW, as hard as the body shop tried, they could ... Sep 9 2016, 06:33 AM
Dave_Darling Your tire guys will not be happy to fit 205s on 8... Sep 8 2016, 09:39 PM
Your tire guys will not be happy to fit 205s on 8... Sep 9 2016, 05:31 AM
mepstein This happens at our shop. We build a car. The cust... Sep 9 2016, 07:27 AM
Philip W. these 16x7" were rubbing and blistered my pai... Sep 9 2016, 07:28 AM
Philip W. This kind is shows the profile after the lip repai... Sep 9 2016, 07:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 02:26 PM |
