| 7TPorsh |
Sep 16 2016, 10:20 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I used search but everything I found had to do with in dash radios. I removed the heater controls and radio space to put in an array of vdo gauges. I don't have a center console.
Now that I have been successful quieting up the car I want to put in some tunes. I want to keep my glove box working so need other ideas. Either a radio....or a way to play music from my phone. |
| Optimusglen |
Sep 16 2016, 10:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
I'm going to use one of these in my build. DROK mini amplifier.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Here it is on my radio delete plate next to a couple stop watches. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1461521472.1.jpg) If you've quieted up your interior a lot it should be enough volume. |
| 7TPorsh |
Sep 16 2016, 12:25 PM
I'm going to use one of these in my build. DROK mini amplifier. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Here it is on my radio delete plate next to a couple stop watches. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1461521472.1.jpg) If you've quieted up your interior a lot it should be enough volume. This is an awesome find....under $15. Probably cleaner output than using bluetooth. The others I have seen have a larger panel; this is only a volume and jack. Does it work well for you? Enough power output? Have to crank Van Halen's first album; only way to listen to it is at 98db! |
7TPorsh Out Of Dash Radio Installations Sep 16 2016, 10:20 AM
Mark Henry
I'm going to use one of these in my build. DR... Sep 16 2016, 05:53 PM
ConeDodger Not exactly sure what McMark is using under the da... Sep 16 2016, 10:29 AM
Mark Henry You will need an amp with that solution.
Woody... Sep 16 2016, 01:55 PM
Andyrew I would combine something like that with a small a... Sep 16 2016, 01:59 PM
Chris914n6 If that little amp doesn't work for you then l... Sep 16 2016, 02:14 PM
Mike Bellis http://www.crutchfield.com/S-BsonLMv6BnP/p...erdas... Sep 16 2016, 04:25 PM
rgalla9146 Dual amps, dual speakers, no antenna Sep 16 2016, 04:37 PM
johnhora :agree:
NO RADIO NECESSARY!
It's just e... Sep 16 2016, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th October 2026 - 01:02 AM |
