| 7TPorsh |
Sep 16 2016, 10:20 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I used search but everything I found had to do with in dash radios. I removed the heater controls and radio space to put in an array of vdo gauges. I don't have a center console.
Now that I have been successful quieting up the car I want to put in some tunes. I want to keep my glove box working so need other ideas. Either a radio....or a way to play music from my phone. |
| Optimusglen |
Sep 16 2016, 10:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest
I'm going to use one of these in my build. DROK mini amplifier.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Here it is on my radio delete plate next to a couple stop watches. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1461521472.1.jpg) If you've quieted up your interior a lot it should be enough volume. |
| Mark Henry |
Sep 16 2016, 05:53 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I'm going to use one of these in my build. DROK mini amplifier. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-19709-1457362751.1.jpg) It's just an AUX-IN with a volume knob. You supply it with 12v, and run the speaker wires. Actually that's not that bad looked at the reviews on amazon, they come in 10wx2, 15wx2 and 35wx2, the 35x2 is $20. Cons is it's for car audio so it runs better at 14v (if you're thinking PC audio, 12v), it gets hot and no case. Also it won't run a subwoofer and is only 2 channel. Pro is it doesn't distort at high volume, sound is pretty good and it's 20 bucks. |
7TPorsh Out Of Dash Radio Installations Sep 16 2016, 10:20 AM
7TPorsh
I'm going to use one of these in my build. DR... Sep 16 2016, 12:25 PM
ConeDodger Not exactly sure what McMark is using under the da... Sep 16 2016, 10:29 AM
Mark Henry You will need an amp with that solution.
Woody... Sep 16 2016, 01:55 PM
Andyrew I would combine something like that with a small a... Sep 16 2016, 01:59 PM
Chris914n6 If that little amp doesn't work for you then l... Sep 16 2016, 02:14 PM
Mike Bellis http://www.crutchfield.com/S-BsonLMv6BnP/p...erdas... Sep 16 2016, 04:25 PM
rgalla9146 Dual amps, dual speakers, no antenna Sep 16 2016, 04:37 PM
johnhora :agree:
NO RADIO NECESSARY!
It's just e... Sep 16 2016, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th October 2026 - 01:03 AM |
