87m491 |
Member ![]() ![]() Group: Members Posts: 330 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
Does anyone have a preferred "shortcut" for removing the retaining "U" tab on the soft line mounts to the body? The bottom ones behind the wheels are a snap as there is plenty of remove to lever with a screwdriver or other, but the upper side which is up at the edge of the engine bay has very little maneuvering room to get a tool in, on , around.
thx Mike |
kid914 |
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,535 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada ![]() |
Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif)
87m491 |
I went with braided only because I could find DOT units and a set of 4 was ~$100. That said even though they were for "Porsche".. the fitting was 11/16ths and not 17mm. I couldn't figure how to get a grip on the clip with vice grips etc. but finally got the retaining clip off by working through the engine compartment and levering with a long screwdriver through the rain drain holes! Hopefully the other side tomorrow!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1474237489.1.jpg) Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 12:45 PM |
