Twin Weber 40 idf's |
JFG |
Oct 10 2016, 12:30 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I bought a set for my 1.7 motor which replaces the missing 2.0 if motor.
I bought these a couple of months ago but have just got around to engine work. This evening I got them out of packing tonight and I think I have a problem. I set them on their manifolds but it looks like they are single sided. They are Italian stamped, 40 IDF. A search finds that they are likely off a fiat or alpha. I did however find a link to a 356 thread which is short and inconclusive. Has anyone fitted this type/model with success? I'll try to get pics uploaded asap. |
ChrisFoley |
Oct 12 2016, 11:18 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It looks like those came off an inline six cylinder engine.
That's why one carb has 3 fuel fittings, one inlet and outlets to the carbs on either side. I believe my linkage can be installed without modifying the carbs, buy you may need to buy a few small parts from Pierce Manifolds or other Weber parts supplier. |
Kansas 914 |
Oct 12 2016, 11:40 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
It looks like those came off an inline six cylinder engine. That's why one carb has 3 fuel fittings, one inlet and outlets to the carbs on either side. I believe my linkage can be installed without modifying the carbs, buy you may need to buy a few small parts from Pierce Manifolds or other Weber parts supplier. (IMG:style_emoticons/default/agree.gif) I am using Chris' linkage - truly a set it and forget application. Always in sync - which is a problem with most bellcrank linkage. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:43 AM |
