Twin Weber 40 idf's |
JFG |
Oct 10 2016, 12:30 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I bought a set for my 1.7 motor which replaces the missing 2.0 if motor.
I bought these a couple of months ago but have just got around to engine work. This evening I got them out of packing tonight and I think I have a problem. I set them on their manifolds but it looks like they are single sided. They are Italian stamped, 40 IDF. A search finds that they are likely off a fiat or alpha. I did however find a link to a 356 thread which is short and inconclusive. Has anyone fitted this type/model with success? I'll try to get pics uploaded asap. |
stugray |
Oct 12 2016, 12:38 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You definitely have either the wrong shafts, or the OP modified them.
On my 40 IDFs, I can put: a bearing endcap washer, spring washer, throttle return spring holder, a thick washer, AND Cris's pulley on my shaft with plenty of thread left over. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1476297510.1.jpg) On your carbs I think you could barely put cris's pulley by itself with enough thread left. |
ChrisFoley |
Oct 12 2016, 01:20 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You definitely have either the wrong shafts, or the OP modified them. On your carbs I think you could barely put cris's pulley by itself with enough thread left. I'm sure the shafts are correct for the application the carbs were built for. I've dealt with this circumstance already and I don't think it will impair proper installation of my kit. I have special throttle stop plates which are thinner than the standard ones. They allow my pulleys to be attached to short shafts where the stock (double layer) plate doesn't leave enough threads. My stop plates aren't part of the kit and they aren't listed on my website but they are described in the linkage installation instructions. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:44 PM |
