> New GB CHT probe NLA closes Oct 29th- if you have the code use today, Code is expiring TODAY $34 we get to get 50 PN 0280130012
Mikey914
post Sep 17 2016, 01:17 AM
The rubber man
Got tired of looking for these some have them listed at $75 and 90, but no Who's interested? I know I need one soon!
Mikey914
post Oct 22 2016, 09:41 AM
The rubber man
I’ve done some research into what Paul Anders detailed in the Djet system.
From his notes on the 0 280 130 003 and 0 280 130 012 versions of this part he mentioned
“012 sensor is in short supply. Either sensor should work OK.”
Looks like the curves are actually within 1.5% for the adjustability mixture control. that's on the rich side (of the 003 sensor) or about .5% of the final mixture (as it's about 30%).
I’ve checked the resistance curve on these and found them to be within 5%. As the fuel control is only adjustable by about 30% it would mean that the potential error would be about 1.5% too rich for a very cold start (about freezing) . the curve closes the warmer it gets.
For those that want to know the actual parts breakdown it goes like this –
70-73 - 1.7 sensor is the 0 280 130 003
74—76 – 2.0 sensor is the 0 280 130 012
73 2.0 used 0 280 130 017 but added a ballast resistor to compensate for the difference in the curve it had. Making it very similar to the 0 280 130 012, but will be richer on warm side and leaner when cold.
So the only thing I can possibly see a problem with is the 73 set up with the resistor present. If this applies to you, it’s possible the curve may be off some. If this is noticeable I can’t say for sure until I have feedback.
Just to note – Do not run ballast with my part with the ballast or wit will just be way too rich.
You will note that the attachment wire protection has been beefed up a little more than the OEM. This is because the wire on the stock part was known to break.
I have been told the 73 ECU will work as long as the ballast is not used.
Thanks
Mark
Mikey914   New GB CHT probe NLA closes Oct 29th- if you have the code use today   Sep 17 2016, 01:17 AM
914Next   Got tired of looking for these some have them lis...   Sep 17 2016, 01:46 AM
Tom_T   Hey Mark, I know that they needed to be the corre...   Sep 17 2016, 06:57 AM
jim_hoyland   Great! Gonna be ok for thT 1.8L L-Jet ?   Sep 17 2016, 08:04 AM
malcolm2   Great! Gonna be ok for thT 1.8L L-Jet ? I c...   Oct 4 2016, 10:06 AM
RohJay   Great! Gonna be ok for thT 1.8L L-Jet ? I ...   Oct 4 2016, 12:32 PM
malcolm2   [quote name='malcolm2' post='2407059' date='Oct 4...   Oct 4 2016, 12:41 PM
hndyhrr   me also, if for 70 1.7   Sep 17 2016, 08:25 AM
Mikey914   Well I have the spec for the 012, so I can make it...   Sep 17 2016, 10:03 AM
Dave_Darling   They're physically the same, the only differen...   Sep 17 2016, 10:27 AM
Tom_T   They're physically the same, the only differe...   Sep 17 2016, 02:23 PM
Marty Yeoman   Mark, MCMark had an alternative design he worked o...   Sep 17 2016, 11:19 AM
Mikey914   Mark, MCMark had an alternative design he worked ...   Sep 17 2016, 04:16 PM
Dave_Darling   I was mis-remembering the CHT sensor info. What I...   Sep 17 2016, 10:51 PM
euro911   So are you probing :miles: the community? :poke: ...   Sep 17 2016, 11:52 PM
Mikey914   Well looks like there is enough commonality that t...   Sep 18 2016, 12:43 AM
McMark   I forwarded my info to Mark so he can proceed with...   Sep 20 2016, 08:14 PM
Mikey914   SO, As noted we will be making the Original Custom...   Sep 21 2016, 12:17 AM
second wind   SO, As noted we will be making the Original Custo...   Sep 22 2016, 01:07 PM
euro911   Yep, need at least one here :)   Sep 21 2016, 04:05 AM
enikolayev   Count me in for one as well.   Sep 21 2016, 06:37 AM
Philip W.   I will take 2!   Sep 21 2016, 06:41 AM
Philip W.   I will take 2! if they are spec for the 2.0 ...   Sep 21 2016, 09:44 AM
Shadowfax   if they are spec for the 2.0 .... Me too. In fo...   Sep 21 2016, 12:31 PM
Java2570   Put me down for one!   Sep 21 2016, 06:56 AM
Mueller   I'm in for one, any discount if I machine my o...   Sep 21 2016, 08:08 AM
914_teener   Mark.....I have one of the Originals that McMark b...   Sep 21 2016, 08:24 AM
jim_hoyland   I'm in too and want to support this   Sep 21 2016, 08:35 AM
CMONNETT   I'll take three for a 2.0 Thanks,   Sep 21 2016, 02:27 PM
Mikey914   Thanks I will update as this progresses. Mark   Sep 21 2016, 10:15 PM
Mike D.   I'm in for 1! :)   Sep 21 2016, 10:29 PM
mangrum   1 for me please.   Sep 22 2016, 07:01 AM
ThinAir   I'm in for one.   Sep 22 2016, 10:00 AM
metalmorphosis   I'm in for one '73 1.7   Sep 22 2016, 10:56 AM
Eric_Shea   six   Sep 22 2016, 03:07 PM
luskesq   One for me please, Keith   Sep 22 2016, 04:05 PM
RobW   I'm in for a 74 2.0 becoming a 2056.   Sep 22 2016, 04:58 PM
turk22   I am in for one, I need the 73 2.0 L specs Its my...   Sep 22 2016, 06:49 PM
914_teener   I am in for one, I need the 73 2.0 L specs Its m...   Oct 4 2016, 09:12 AM
zambezi   I'm in for 1. '73 2 liter. Jim   Sep 22 2016, 06:54 PM
warrenoliver   I'm in for one for a '73, 2.0. Thanks   Sep 22 2016, 08:01 PM
Yanlx   5 for me please 73 2.0 thanks   Sep 28 2016, 12:17 PM
Marty Yeoman   Add my name to the list for one. Can you provide s...   Sep 28 2016, 01:54 PM
Mikey914   Testing the parts now. But no, stock only for thes...   Sep 28 2016, 03:08 PM
second wind   Hey Mark.....so only 012 and not 017's?   Sep 28 2016, 04:21 PM
Mikey914   Hey Mark.....so only 012 and not 017's? This...   Sep 29 2016, 01:28 AM
Jeff Bowlsby   I am down for 2 of the 012 Mark.   Sep 28 2016, 05:13 PM
euro911   Jeff, off the top of your head, what would a 1.7L ...   Sep 28 2016, 06:33 PM
Mikey914   Jeff, off the top of your head, what would a 1.7L...   Sep 28 2016, 07:20 PM
StratPlayer   1 012 for me please   Sep 28 2016, 06:36 PM
Jeff Bowlsby   A 1911 is a custom set-up so I cannot help you the...   Sep 28 2016, 07:31 PM
RohJay   Please count me in for ONE. Thanks   Sep 29 2016, 02:14 AM
McMark   This CHT should never be used with the 73 ballast ...   Sep 29 2016, 07:19 AM
pch1north   Got tired of looking for these some have them lis...   Sep 30 2016, 01:02 AM
pch1north   I'll take 2 74 2.0   Sep 30 2016, 01:11 AM
saigon71   One for me please. Thanks Mark! :beer2:   Sep 30 2016, 06:41 AM
BeatNavy   It looks like you've made your bogey, Mark, bu...   Oct 4 2016, 07:33 AM
Mikey914   Drawing done. Stock inbound and will be cutting me...   Oct 4 2016, 04:46 PM
malcolm2   any update on this part?   Oct 18 2016, 09:19 AM
Mueller   Count me in for one please.   Oct 18 2016, 09:57 AM
Mikey914   We are starting to cut metal and have the componen...   Oct 18 2016, 10:19 AM
Mikey914   Got on these a little earlier than I planned (burn...   Oct 20 2016, 12:07 AM
Yellow Resi   Got on these a little earlier than I planned (bur...   Oct 21 2016, 04:18 PM
Mikey914   PMs going out to all   Oct 20 2016, 01:47 AM
euro911   :thumbsup: Looks like you might have a larger ma...   Oct 20 2016, 02:36 AM
Mikey914   Paul Anders mentioned they were interchangeable. C...   Oct 20 2016, 02:44 AM
Jett   Mark, if it's not too late I will take 4 (1.7,...   Oct 20 2016, 08:10 AM
brownaar   I'll take 2. Aaron   Oct 20 2016, 12:35 PM
Marty Yeoman   PayPal sent.   Oct 20 2016, 05:08 PM
Mikey914   Codes sent to those that bumped. The production on...   Oct 20 2016, 09:18 PM
euro911   Thank YOU, Mark :worship: Paypal sent for 1 CHT...   Oct 20 2016, 11:16 PM
RohJay   Mark, I have not received a PM...   Oct 21 2016, 12:14 AM
hex9145   If still available I'll take one   Oct 21 2016, 11:08 AM
Java2570   Just ordered mine, thanks for doing these Mark...   Oct 21 2016, 07:20 PM
Wyvern   I this will work for a '73 1.7 I would like on...   Oct 21 2016, 07:40 PM
RohJay   I this will work for a '73 1.7 I would like o...   Oct 21 2016, 11:36 PM
Mikey914   I’ve done some research into what Paul Anders de...   Oct 22 2016, 09:41 AM
Rob-O   I'll take one.   Oct 22 2016, 01:40 PM
Mikey914   Pm sent. I will be closing out this group buy the...   Oct 22 2016, 02:53 PM
914four   I'll take one for a '74 2.0L. Please incl...   Oct 23 2016, 09:05 AM
RohJay   Mark, I still have not received your PM with The C...   Oct 23 2016, 05:36 AM
Mikey914   Sent to all if I missed someone let me know. Mark   Oct 23 2016, 09:49 AM
malcolm2   Are we supposed to place and order on the website?...   Oct 23 2016, 03:27 PM
Mikey914   If interested you put your name down on the list h...   Oct 23 2016, 04:15 PM
Jboulder   I'll buy one! Thanks, Jackson   Oct 25 2016, 04:41 AM
Niklas   I take 4. Niklas   Oct 25 2016, 06:23 AM
914Sixer   I will take 1 to go with the 2 ECU caps.   Oct 25 2016, 02:18 PM
Mikey914   PMs sent to all   Oct 25 2016, 05:58 PM
Optimusglen   This may be a dumb question, for for cars converte...   Oct 26 2016, 07:23 AM
pilothyer   This may be a dumb question, for for cars convert...   Oct 26 2016, 08:18 AM
pilothyer   I need one Mark.......Thanks.................Jerry   Oct 26 2016, 08:21 AM
hex9145   I'll take one please.   Oct 26 2016, 12:28 PM
VoPo914   I'll take one 2.0L. Thanks-Blaine   Oct 26 2016, 12:36 PM
TX914   Mark, please include me in the group buy for a 0 2...   Oct 27 2016, 06:04 AM
sb914   I'm in for one   Oct 27 2016, 06:37 AM
Firstcar   Mark, I'll take one a 0 280 130 012 version (...   Oct 27 2016, 12:23 PM
Rob-O   Got the PM with the code, but can't find this ...   Oct 27 2016, 09:23 PM
Rob-O   Oh for crying out loud...I found it!   Oct 27 2016, 09:24 PM
sofi2t81   I'm in for one 74, 2.0 Peter   Oct 28 2016, 04:04 AM
Porschef   Yeah, me too. Just in case. Thanks for makin...   Oct 28 2016, 04:23 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:06 PM
